Date: 01-05-26  Time: 21:24 pm
Author Topic: Indercators not working fazer 1000  (Read 4916 times)
2wheelsonly
« on: 08 July 2019, 08:57:23 am »
Hi guys
I need your help my 2002 fazer 1000 has a indercators has stopped working I've changed the handle bar switch cleaned every connection with contact spray I'm at my wits end with it now. It has a Meta alarm system on it and the indercators work with that. Any one any insight..  :'(
Geowulf
Re: Indercators not working fazer 1000
« Reply #1 on: 08 July 2019, 09:11:24 am »
Possibly the indicator relay is focced, it's located by the battery, it's a cheap swap.
I changed my indicator relay when I swapped to LED indicators, it literally takes a minute.
2wheelsonly
« Reply #2 on: 08 July 2019, 09:20:20 am »
Is that two pin there's a round relay beside the battery it looks after market it only has tow connectors
Geowulf
« Reply #3 on: 08 July 2019, 09:25:51 am »
From memory, it's two or three pin and square not round
2wheelsonly
« Reply #4 on: 08 July 2019, 11:01:12 am »
I'll order one and see if that's it. Appreciate your help thanks
tommyteeman
« Reply #5 on: 08 July 2019, 08:51:12 pm »
Use a multimeter on the wires to the indicator relay, there's two wires, turn a blinker on see what the reading is, if there's no power going to the relay the problem can lie with the ignition switch. I had the same problem and found the bolts that hold the ignition switch together (where you put the key in ) had come loose and although everything else worked fine the blinkers didn't. I tightened the bolts inside the switch housing and it sorted it. Could be the relay though , but if your indicators work with the alarm then could be that. I stripped the alarm off mine years ago it was a pita !
2wheelsonly
« Reply #6 on: 09 July 2019, 08:53:24 am »
I'll try that too they some times work only for about 30sec or so. I taut it was a bad connection or a broken wire but I've been through the hole lot. I'll check the gig and change the relay and hopefully that solves the problem  ;)
2wheelsonly
« Reply #7 on: 11 July 2019, 05:35:28 pm »
Problem was the relay beside the battery it's a cheep after market led one I've a original one on the way so I'm 😊
