Date: 25-05-26  Time: 10:17 am
Author Topic: FZS1000 gearbox woes  (Read 12173 times)
binarystarr
« on: 10 April 2012, 06:44:02 pm »
Hi
Picked up my 02 bike on saturday and am having problems already.
Shifting up is incredibly difficult and i often have to re-engage the clutch and try again with quite a bit of force to get it to click into place.
This obviously isn't normal - should i take it back to the dealer or are there some quick fixes i could try? It's done 34000 miles and has some service history but not much.
Any advice would be really appreciated.
james43
Re: FZS1000 gearbox woes
« Reply #1 on: 10 April 2012, 08:28:53 pm »
Hi I've got an 05 Gen1 that's done 32k. Mine changes as sweet as as a nut like the day it rolled off the production line.
So I would say it's not mileage related.
Unless its been ridden like a Tw*T.
I would suggest taking it back as you bought it from a dealer & if they tell you its age or mileage related tell em its a load of old guff.
You could always name & shame the dealership here to give you an idea if anyone else has had problems with them.
James43
Falcon 269
« Reply #2 on: 10 April 2012, 09:26:37 pm »
Hi and welcome. :)
Hopefully something as simple as misaligned or partially seized Rose joints on the shift linkage, corrosion on the gear lever pivot or a maladjusted clutch operating mechanism.
However, could also be indicative of internal gearbox problems (ie, shift forks damaged) so don't mess with it.  Take it straight back to the dealer and don't take it off them again until it's 100% right.
ghostbiker
« Reply #3 on: 10 April 2012, 11:32:15 pm »
Might be worth lowering the gear leaver a little and checking chain adjustment. But as others have said try the dealers first.
« Reply #4 on: 11 April 2012, 06:52:03 am »
back to the dealer...thats why you bought from him and not going private...good luck  :)
binarystarr
« Reply #5 on: 11 April 2012, 08:35:39 am »
Thanks all, to the dealer it is! Will let you know how i get on.
locksmith
« Reply #6 on: 11 April 2012, 03:06:21 pm »
Bummer, you buy from a dealer expecting pure joy.
Hope it's simple and they play ball.
binarystarr
« Reply #7 on: 12 April 2012, 10:32:00 am »
Well, i went to see them yesterday and typically the box was working fine. A mechanic took it out for a spin and came back saying it was fine but perhaps the lever needed some adjustment, which he did and now things are much better.
Panic over ;)
It's still not brilliant but i'm shifting up without bothering with the clutch most of the time now. When i get some time i will pull things apart and give them a good going over.
Will put this down to teething troubles.
Phil TK
« Reply #8 on: 12 April 2012, 02:02:08 pm »
I would say that the Fazers gearchange isn't the slickest out there anyway, it's typical vintage Yamaha ie  you feel a minor click sensation then a fair bit of movement until the lever goes solid  'click, thunk'
My Fazer is one of the few bikes I've had where I don't get too clever with clutchless changes, I almost always use the clutch at lower rpms in all the gears, when you are filtering 'progressively' at low speed it's safer that way too.
binarystarr
« Reply #9 on: 12 April 2012, 04:32:28 pm »
Cheers Phil, your description of how this feels spot on. I'll get used to that vintage feel then ;)
Falcon 269
« Reply #10 on: 12 April 2012, 05:43:23 pm »
Sorted, good. :)
I think it's still worth cleaning, greasing and aligning the linkage mechanism.  Also, don't forget the R1 shift arm mod. :)
mcyoungy
« Reply #11 on: 12 April 2012, 05:56:42 pm »
what's with the R1 mod? is this a very good thing to do?
locksmith
« Reply #12 on: 12 April 2012, 07:10:39 pm »
Echo what Mike said, give the linkage a good clean/grease/adjust.
paul.s
« Reply #13 on: 13 April 2012, 07:28:04 am »
ill second this after coming from suzuki,s i was a little concerned about the gearchange when i bought my gen 2 but apparently they are all like this
tomlinscote
« Reply #14 on: 13 April 2012, 08:15:54 am »
Another vote for using the clutch and I have had my gen1 from new, but it hardly ever 'finds' a false neutral. Suzuki are known for slick boxes so yoiu may have been spoilt :) I have tried a GS1200 and that had a lovely change but not sure I could get used to the huge vibes below 3500 rpm.
Cheers
P
Falcon 269
« Reply #15 on: 13 April 2012, 08:19:18 am »
Yes, a good mod and worth doing.  Shortens the gearchange lever movement considerably.
http://www.yamahafz1oa.com/forum/showthread.php?t=23754&highlight=r1+shift+arm
binarystarr
« Reply #16 on: 13 April 2012, 03:58:03 pm »
That mod looks the business, got to be done.
mcyoungy
« Reply #17 on: 13 April 2012, 04:09:05 pm »
yeah I found coming from the R1 to the Fazer that the gear lever throw was very long.......... thought it was jut me and I'd get used to it. now I know..................  :)
