Date: 02-05-26  Time: 20:07 pm
Author Topic: FZ1 09 plate Spark plug change  (Read 3287 times)
Timbo
« on: 06 July 2019, 02:57:40 pm »
Hi all
Pointer please ..... how to you access the spark plugs to change them.
From the top or is it from the front\side. How much have you got to take off to access them?
Thanks
Bw
robbo
Re: FZ1 09 plate Spark plug change
« Reply #1 on: 06 July 2019, 03:05:36 pm »
Sounds like you've still got the AIS on your bike, in which case it's a matter of time and patience. Many have removed the AIS which makes plug changing and cleaning the cam covers a breeze.
Timbo
« Reply #2 on: 06 July 2019, 05:10:24 pm »
Are you saying you cannot get to them without removing the AIS?
Bw
robbo
« Reply #3 on: 06 July 2019, 05:53:28 pm »
No, just that by removing the AIS, plug removal is a piece of cake rather than a struggle, and is cheap enough to blank off the holes that are left. Saves a minimal amount of weight as well.
Dudeofrude
« Reply #4 on: 07 July 2019, 10:36:06 am »
Hi all
Thanks
Bw
With the AIS still installed you will have to take the tank and air box off to gain proper access.
With the AIS removed it is possible ( but still hard) to do them just by dropping the radiator off its mounts then using multi joint ratchets.
Either way it's a pain in the arse compared to other bikes I've owned 🙄
robbo
« Reply #5 on: 07 July 2019, 11:41:18 am »
I was assuming Timbo has a Gen 1. If that's not the case then ignore anything I've posted as I have no knowledge of Gen 2's.
robbo
« Reply #6 on: 07 July 2019, 11:46:39 am »
Doh,
I've just realised the title of the topic doesn't match the posters profile. I'll get me coat :lol .
steve 10562cc
« Reply #7 on: 07 July 2019, 05:00:41 pm »
Not long done mine on 08 FZ1 just loosened the rad wasn't to bad to do, worst bit is getting the coil sticks out. Have the plasters handy skinned a couple of knuckles though.
Timbo
« Reply #8 on: 07 July 2019, 05:14:31 pm »
Doh,
Ah yes..... I do have a Gen 1........ No1 son has a Gen 2
Bw
Hamos
« Reply #9 on: 16 July 2019, 12:31:01 am »
Just loosen rad on mounts. I changed coolant at same time so you can remove a radiator hose to make access easier.  Space Is tight but manageable with some swearing.
Timbo
« Reply #10 on: 06 August 2019, 05:15:05 pm »
All done, quite easy in reality but we drained the coolant\dropped the rad to do it which seems a lot of work for a plug change!!  :)
My FZS1000 is a lot easier!! :rolleyes
Bw
