Date: 25-05-26  Time: 05:35 am
Author Topic: ###Fazer 1000 clutch PROBLEM Help please###  (Read 10639 times)
jp2000
« on: 10 June 2019, 07:53:14 pm »
Does anyone have an old shaft lying about that I could buy the center cap from please or know where I could get one.
Mine is missing on my new to me bike I have no idea where to get one any help greatly appreciated.
midden
steve 10562cc
Re: ###Fazer 1000 clutch PROBLEM Help please###
« Reply #2 on: 11 June 2019, 04:30:47 am »
Try Ebay they do come up quite often
« Reply #3 on: 11 June 2019, 06:10:28 pm »
Just spoke to a fellow who is into vintage cars about this and he thinks you might be able to get a core plug in the Local Engineering machine shop, not sure of the size of the one on the Fazer/R1. Considering how many I have come across (mostly R1s), I never thought of measuring it. Not sure who suggested measuring the hole on the Facebook post as I cannot find the post now. It may be a 1/2" as they are a common enough oil way plug apparently.
For future info : Generally the Fzs1000 is very easy to get  neutral as a stand still, , if you suddenly have problems getting neutral and the clutch drags a bit this is usually the issue, core cap/llug has popped out of the end of the clutch shaft and will normally sit in the clutch basket as it cannot go anywhere.. Since yours was not there it is safe to say the previous owner may have replaced the clutch in a bid to fix the issue and lost the cap. Many Fazer/R1 were sold because of this issue which as I mentioned  in your Faccebook post was probably why yours was sold off relatively cheap.
jp2000
« Reply #4 on: 11 June 2019, 08:40:17 pm »
Thank you for the help. Plug ordered from eBay for the princely sum of £1.96 looking forward to fitting and getting out on the road. So nice to be part of a group of genuinely nice and helpful people.
« Reply #5 on: 11 June 2019, 10:42:37 pm »
Hope you kept the clutch plates in order to ensure you put them back in the same way they came out
jp2000
« Reply #6 on: 11 June 2019, 11:03:01 pm »
Yes but I'm not sure they were correct.
jp2000
« Reply #7 on: 11 June 2019, 11:04:50 pm »
Any info on correct order so I can check there right would be very much appreciated.
ArchDruid
« Reply #8 on: 12 June 2019, 05:56:59 pm »
From the Haynes manual :
First fit the type B friction plate, (which is thicker and has the larger internal diameter) so it fits over the anti-judder spring & seat. Now fit a plain plate, followed by a blue colour coded type A friction plate, then alternate plain and friction plates, fitting the two remaining blue-coded friction plates, then the four black-coded type A friction plates.
Hope that helps.
Btw, Haynes manual is a decent investment. Less than £20 on ebay…..
« Reply #9 on: 12 June 2019, 08:43:28 pm »
Hope that helps.
If OEM plates are fitted, then above is correct, if there is no colour coding then they are pattern plates and you will have to put them back on as they came off.
You can download the service manual in the downloads section along with a few other useful bits.
jp2000
« Reply #10 on: 13 June 2019, 11:04:58 am »
Thanks for all the advice plug fitted clutch now working. haynes manual ordered. :D
Freck
« Reply #11 on: 13 June 2019, 12:41:21 pm »
You didn’t need to order a Haynes manual, they’re free to download here
http://foc-u.co.uk/index.php?action=downloads;cat=1
« Reply #12 on: 13 June 2019, 01:10:11 pm »
Another happy Foccer  :lol Don't forget this section of the forum  :eek http://foc-u.co.uk/index.php?action=downloads
sharkbite34
« Reply #13 on: 16 January 2022, 05:11:58 pm »
Hi guys,
Having the same clutch problems as described re core plug, anyone have a photo or link to buy a new one??cheers guys
« Reply #14 on: 16 January 2022, 10:33:53 pm »
Buy a core/frost plug in the local motor factors 12mm or 1/2inch as far as I can remember from the last one I did on an R1
Decoke Dave
« Reply #15 on: 26 January 2022, 02:41:27 pm »
 Sorry, but please bear with me here!  :'( I’ve looked at this post a couple of times, looked at the Fowler’s exploded view of the clutch parts and still cannot understand what this “centre cap” item is or where it goes. Had bike clutches stripped several times. Not an FZS one I admit!  :o   What is the part number on Fowler’s exploded view? Or is it supplied with shaft, item 20?
« Reply #16 on: 26 January 2022, 06:26:56 pm »
Here you go
Decoke Dave
« Reply #17 on: 26 January 2022, 09:56:11 pm »
    Perfect!  Many thanks unfazed, good to understand for the future if clutch issues arise!
