Date: 02-05-26  Time: 21:11 pm
Author Topic: 24000 mile service  (Read 3318 times)
Stew53uk
24000 mile service
« on: 08 June 2019, 05:18:50 pm »
hi all I am new to this site and after some advice/help please. I am looking at an fzs1000 for sale. It cannot be confirmed by the owner if it has had its 24000 mile service which means it will need to be done. It’s just done 24000 miles and is up for £2400 with history (allegedly). Firstly is it worth the money, it’s in nice condition, secondly can anyone help me with the service as I know it’s a big one, thanks in advance?
celticbiker
Re: 24000 mile service
« Reply #1 on: 08 June 2019, 06:36:14 pm »
The 24000 mile service includes things that really shouldn't need doing.
Head bearings greased and checked, same with swing arm, chain check and adjust, brakes and fluids etc etc.
A lot of it is stuff that should be done regular anyway.
When I take my Fazer 8 I change oil and filter before it goes and all they do is strip, check valve clearance and rebuild with new plugs and tb balance.
Drop it off Friday night pick it up Saturday afternoon.
That said if you are buying it, it might be worth having a full dealer service so you know that you are starting with a good, well serviced bike.
PieEater
« Reply #2 on: 09 June 2019, 12:09:26 am »
Hi and Welcome  :)
It's up to you if you are willing to spend big money on a full service on a bike that is of an age....I can tell you that in all my time on these forums I can't recollect anyone's valves needing adjustment at 24K or even 50K so the chances are you will be OK if the bike looks like it has been well looked after and not neglected. I think £2400 is quite steep unless you are getting a bike with all of the essentials done - replacement rear shock, replacement brake hoses, front forks re-sprung, Ivanised carbs, decent aftermarket end can etc.
Checkout the FAQ if you haven't already as there are some giveaways as to how the bike has been looked after (EXUP / Fork damping adjusters / exhaust headers).
I hope that helps but feel free to post back with any questions and let us know how you get on.
VNA - BMW Wank
« Reply #3 on: 09 June 2019, 12:21:24 pm »
 If the valve check is due and it’s not been done then that’s a good bargaining chip.
Price on bikes this old, I figure is almost purely dependant on condition.
As Pieeater says check the EXUP valve, if it’s present and working that is one indicator the the bike is looked after.  If the OE is shock is still in there (it was never much good) – budget for a replacement – so another bargaining chip.
If the owner can demonstrate that it’s been Ivanised – a lot have – that’s a bonus.
I bought mine new in 2004.  It got the valve check at 30,000 miles – no adjustment required.
Good luck.
celticbiker
« Reply #4 on: 09 June 2019, 12:55:58 pm »
In all honesty I've never needed any clearances changed even on bikes with over 130000 miles on them but I still have them checked just in case.
Mustang
« Reply #5 on: 09 June 2019, 07:41:41 pm »
I checked the valves on my bike at 36000, loads of them were out.
midden
« Reply #6 on: 09 June 2019, 10:43:24 pm »
Do you remember before you physically checked them, were there any tell tale signs to indicate they were out, perhaps from the exhaust?
« Reply #7 on: 10 June 2019, 10:51:41 am »
I check mine on the 1000 and 600 religiously at the 24000 mark. The 1000 had 8 out of spec where as the 600 were al within spec. At the 48000 mile mark the 1000 was fine but the 600 had 5  out of spec. At 72000 on the 600 all were within spec. My advice is to check them at the recommended intervals as you will not know from listening to the engine if clearances are tight. The old adage "Loose tappet annoys the rider , tight tappets annoys the engine" It will give you peace of mind also knowing everything is fine.
Mustang
« Reply #8 on: 10 June 2019, 08:29:51 pm »
No it was starting and running fine
