Date: 15-03-26  Time: 00:05 am
Author Topic: Installing a GiPro X-Type Gear Indicator  (Read 8401 times)
Bertie78
« on: 23 May 2019, 12:25:41 pm »
Hi all,
I'm currently trying to install a GiPro gear indicator, and whilst I'm no idiot when it comes to wiring etc, I'm struggling with the instructions a bit. So the bit I'm struggling with is the "Crankshaft position sensor", mentioned in step 3a of the instructions (attached). Could anyone give me some pointers to identifying the necessary parts? A picture with red circles would be helpful. :)
Tia.
agricola
Re: Installing a GiPro X-Type Gear Indicator
« Reply #1 on: 23 May 2019, 06:01:31 pm »
Hold everything a short while whilst I look out my old fitting instructions for ya
agricola
« Reply #2 on: 23 May 2019, 06:10:30 pm »
First up we need to confirm that youve got the correct kit for the FZ6 S2 fazer : Gipro X-type GPX-U01
and you you get the harness kit with it?
Bertie78
« Reply #3 on: 23 May 2019, 07:37:39 pm »
Hiya,
Thanks for answering. I forgot to put it's the G2 version, if that makes any difference? So i have the non abs S2, so the compatibility came up as the GPX Y01, which i have.
agricola
« Reply #4 on: 23 May 2019, 08:46:03 pm »
heres a link to the supplementary manual
Us eit in conjunction with the following instructions:
1. remove the seat and find the ECU connector
2. Splice the red GPX wire to any +12volt switched power lead eg to the red/white wire at the ECU connector
3. Splice the black GPX wire to the chassis ground, or the negative battery terminal
4. Splice the white GPX wire to the white yellow (speed signal) wire at the ECU connector
5.Splice the green GPX wireto the grey (crankshaft sensor signal) wire at the ECU connector
Dont commit to cutting/spilcing into any wires unless you are 100% certain youve got it.
Just bear in mind that nos 1 to 5 above are for the U01, and there may or may not be wire colour changes between ythe 2 bikes. And a word of warning, there is very little slack in the cables under the tank. Where it says "at the ECU connector" find the right wire and then follow it away a little from the connector until you have enough room for the splice to locate. I used a pair of tweezers to tease the wires until id got enough slack to splice with. Its very, very tight under there. Youy will need patience
Bertie78
« Reply #5 on: 27 May 2019, 11:02:51 pm »
A thousand thank yous. I followed the supplementary guide and it was exactly what I needed. The colours and positions of the required wires was spot on. And now i have got it installed and working!
Dynspud
« Reply #6 on: 28 May 2019, 06:14:52 am »
Any piccies?
agricola
« Reply #7 on: 28 May 2019, 06:09:44 pm »
Well done :thumbup
Steve3351
« Reply #8 on: 31 May 2019, 03:22:31 pm »
INTERESTING....
Can u get a gear indicator for Fazer 600 5DMC...2001 model...?
Half the time i'm riding I don't know wot gear I'm in...have to keep checking by changing up into "seventh"... :book
agricola
