Date: 20-03-26  Time: 10:55 am
Author Topic: Phone charging on the bike  (Read 2150 times)
fireblake
« on: 17 May 2019, 02:29:09 pm »
So what are you guys using to charge your phone's on your bike? Preferably near the handle bars so I can use it as a twat nav. Plus a charger for a camera battery?
I've looked at the older threads on here but none of the links seem to work anymore so some fresh links would be great too
Thanks,  Mickey
Dudeofrude
Re: Phone charging on the bike
« Reply #1 on: 17 May 2019, 02:54:49 pm »
I just use a standard motorbike 12v USB socket then plug my phone into it using the charging cable and have my phone in a phone holder on the bars
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F312610064526
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F123750592987
mickvp
  • Global Moderator
« Reply #2 on: 17 May 2019, 04:13:26 pm »
I actually just ordered one of these last night:
FREESOO Motorcycle USB Socket Waterproof 3.0 Fast Charger Dual Power Outlet 12V-24V https://www.amazon.co.uk/dp/B07MV4WN33/ref=cm_sw_r_cp_api_i_C9S3Cb8QPF5FV
I’ll let you know how good it is when it comes in (tomorrow).
fireblake
« Reply #3 on: 19 May 2019, 02:47:36 pm »
Well I bought the 12v socket that Dude put up but I might just buy the one Mick put up too as It has super fast charging which my phone prefers. What about power packs? Handy to have a little bit of power when the engine is off
Mickey
« Reply #4 on: 20 May 2019, 06:53:17 am »
I just bought a power bank for my phone, and gave it a quick test last night.
Charging a Samsung 9+ it took just under 90mins to charge 40% of the phone battery to full (started on 60%).
This particular power bank used 4% of its power per 10% of phone charge, so ended the charging still with 84% power left.
I did have an app running in the background during this time, and as i would normally put it into Aeroplane Mode to cut out all outside interference i do believe the charging time could be improved quite a bit, i will try it again soon and let you know, but i had to have the phone reachable yesterday as i was on call for work.
The power bank has 2 outputs, one @ 1A, and the other @ 2.1A which is the one i was using.
So on yesterdays evidence, seeing as my phone very rarely goes below 50% power in a day, i could theoretically get 5 days of charge out of it with no external power sources at all, although in the real world i would probably safely say 4 days.
Either way it's a bloody handy bit of kit for very little money. You can get bigger, faster and more expensive ones, but this was thin, lightweight and about the size of an average phone than can easily go in your pocket if necessary without feeling like you're carrying a brick about with you.
NOTE: It only comes with a USB to battery pack charger lead, so will need a USB Mains plug adapter to charge it. If you need to purchase one make sure you only buy one that puts out a minimum 2.1A, as anything less will take forever to charge.
And the outputs on the power bank are USB so you will need a USB cable to whatever connector your phone takes when charging it.
https://www.ebay.co.uk/itm/Ultrathin-50000mAh-LCD-Power-Bank-Portable-2USB-LED-Battery-Charger-For-iPhone-X/142745227181?ssPageName=STRK%3AMEBIDX%3AIT&var=441746815896&_trksid=p2057872.m2749.l2649
NOTE: Buy at least the twin version.
https://www.ebay.co.uk/itm/UK-Mains-Wall-3-Pin-Plug-Adaptor-Charger-Power-4-USB-Ports-for-Phones-Tablets-CE/223476533247?ssPageName=STRK%3AMEBIDX%3AIT&var=522232631960&_trksid=p2057872.m2749.l2649
fireblake
« Reply #5 on: 21 May 2019, 05:55:20 pm »
Great info Darrsi
