Date: 25-03-26  Time: 17:45 pm
Author Topic: Starter relay  (Read 2283 times)
Slippy
Starter relay
« on: 13 May 2019, 10:48:49 pm »
My bike wont start! The starter relay has the red cable connected from the battery but the black cable has come loose. Does any one know what bolt size I need to re-attach. Attached a picture to make more sense.
Disorderlypunk
Re: Starter relay
« Reply #1 on: 14 May 2019, 05:29:32 am »
prob an m6/m8  just pop down Wilko's and grab the shortest you can
Jules-C
Re: Starter relay
« Reply #2 on: 14 May 2019, 06:32:28 am »
M6 and about 10mm long.
Slippy
Re: Starter relay
« Reply #3 on: 14 May 2019, 07:49:45 am »
Thanks for that! Have no how it has managed to rattle itself loose
Freck
Re: Starter relay
« Reply #4 on: 14 May 2019, 01:04:21 pm »
Just take the one off the red cable, it'll be the same size i bet. :)
Jules-C
Re: Starter relay
« Reply #5 on: 14 May 2019, 01:17:36 pm »
Disconnect the battery negative lead first to prevent accidentally shorting the positive to the frame
Disorderlypunk
Re: Starter relay
« Reply #6 on: 14 May 2019, 02:18:33 pm »
why do i have a feeling that problem took a fair while to find, blaming clutch and stand switches first
Slippy
Re: Starter relay
« Reply #7 on: 14 May 2019, 06:44:21 pm »
I had a guess it was the starter relay straight away because it was ticking when the bikes turned on
His Dudeness
Re: Starter relay
« Reply #8 on: 14 May 2019, 08:05:08 pm »
Is that a bit of burning on the relay where the bolt was? If the bolt was loose it would cause a bad connection and high resistance and that causes heat and possible burning or arcing. If it is burnt give it a clean.
