Date: 15-03-26  Time: 00:06 am
Author Topic: 2004 FZ6 ignition switch  (Read 8479 times)
fazermike
« on: 08 May 2019, 06:24:51 pm »
Hi Guys,
the ignition switch on my 2004 FZ6 only switches on after several attempts and if I use the steering lock it is virtually impossible to unlock again.
So I want to replace it which means changing the fuel cap and seat lock.
I have seen some cheap ones on ebay. which are probably rubbish so i looked on WEMOTO website and they has a complete kit for £42, my only concern is if i change it was happens with the immobiliser?
isn't there a chip in the key that communicates with the bike so it can be started?
Re: 2004 FZ6 ignition switch
« Reply #1 on: 08 May 2019, 07:33:05 pm »
Did you try soak the lock in WD40? Spray plenty in via the key slot, leave it soak for a while and try turning it a few times.
Grahamm
  • Global Moderator
« Reply #2 on: 09 May 2019, 01:19:18 am »
Have you checked to see if the key is worn? If you have the Red Key, compare it with the one you're using.
fazermike
« Reply #3 on: 24 August 2019, 11:12:19 pm »
Tried all the keys and it's the same story!
the ignition barrel shouldn't be worn as the bike has only done 8,000 miles'!
Trebus
« Reply #4 on: 25 August 2019, 09:10:10 am »
Try some graphite powder before changing it. This is the correct stuff for lubricating the barrel.  Kasp K30050 Graphite Powder by Kasp https://www.amazon.co.uk/dp/B01MYMZ2DI/ref=cm_sw_r_cp_api_i_FoKyDbAM6FR53
The bolts will be anti tamper so will need to be drilled out, makes it a fair bit of work as the yoke needs to be on the bench.
M4RTIN
« Reply #5 on: 07 September 2019, 02:46:27 pm »
Put the key in and pull it backward toward you and try and turn it at the same time..Wife Fazer 6 she has to pull it backwards, and one of my zx9r i have to push it forward to turn on..
agricola
« Reply #6 on: 07 September 2019, 08:17:48 pm »
Mines been like it since I first had the bike 5 years ago. I try not to force it  as I dont wnat to have to try to remove a broken key. I pour ACF50 down the key slot several times a year to keep it moving
