Date: 12-05-26  Time: 05:26 am
Author Topic: Ignition Advancer  (Read 4781 times)
Johnnylad123
Ignition Advancer
« on: 25 April 2019, 08:04:20 pm »
I've bought a 4 deg ignition advancer, but when I've tried to fit it I can't get the bolt holding the original to slacken.
I do have an impact driver and an air powered rattle gun but due to it being on the crank end I didn't fancy risking it, what has everyone else used to crack the threadlock??
ogri48
Re: Ignition Advancer
« Reply #1 on: 25 April 2019, 08:52:37 pm »
heat will debond threadlock mate
mickvp
  • Global Moderator
« Reply #2 on: 25 April 2019, 10:00:01 pm »
I’m not recommending you do this, but I just stuck mine in first gear, on side stand, one foot on rear brake and it came loose no bother 😳
Johnnylad123
« Reply #3 on: 25 April 2019, 10:10:09 pm »
I tried the in gear and brake method but no joy.
I have a heat gun for paint stripping but given there's oil and the electric pickup in close proximity to the bolt I decided against it! Any recommendation as to what heat source would me much appreciated!!
« Reply #4 on: 25 April 2019, 10:37:56 pm »
No Thread lock on that bolt (at least there shouldn't be) just 60 Nm of torque. I usually remove the hugger, brush handle through the wheel and rest on the swinging arm, into 4 gear and 1/2 drive and a long breaker bar.
ogri48
« Reply #5 on: 25 April 2019, 11:35:14 pm »
eeeek! all sounds very worrying lol. is the advancer worth it? I tried one on my bandit twelve years back and it actually lost bottom end...been sceptical of em ever since
Johnnylad123
« Reply #6 on: 26 April 2019, 07:40:36 am »
That's my thoughts now Ogri, it's already cost me a gasket so for all the faff most likely won't do it.
Ebay it is!
ogri48
« Reply #7 on: 26 April 2019, 10:25:00 am »
 :thumbup I even had the bandit dynoed at bsd to check, it definitely mullered the bottom end. Though ive read good things on here in the past. I always think my thou has ample bottom  (especially after ivanising it) then I jump on me cb1300 and suddenly the thou lump feels like a sports 600 lol
PieEater
« Reply #8 on: 26 April 2019, 11:16:24 am »
Advancer gives a noticeable boost to bottom end and makes cold starting a tad easier, trade off is a slight loss of top end but unless you spend the majority of the time caning the bike the benefits easily outway the costs. Having said that I wouldn't say that it's worth risking engine damage to fit and in this case it's probably best leaving well enough alone unless you take it to a shop to have it fitted and they assume all responsibility .........
Johnnylad123
« Reply #9 on: 26 April 2019, 04:35:15 pm »
My thoughts exactly PieEater, I reckon the rattle gun would do the trick but at what cost to the bottom end of the motor. Just not worth it I'm afraid.
kebab19
« Reply #10 on: 26 April 2019, 06:06:10 pm »
Providing you have something to balance it on, you could could rest the tip of a soldering iron to the bolt and leave it touching for for 5 - 10 minutes? It would be a more precise way to apply heat to a specific area without risking damage to the surrounding parts.
happycallis
« Reply #11 on: 19 June 2019, 12:47:11 pm »
Where does everyone get their advancers from?
CatalinU
« Reply #12 on: 10 December 2019, 04:51:40 pm »
Been reading this and thinking myself on changing it. What are downsides of having the 4 degree plate on?
PieEater
« Reply #13 on: 11 December 2019, 08:44:09 am »
https://www.ebay.co.uk/itm/Y005-YAMAHA-R1-FAZER-1000-CARB-MODELS-4-DEGREE-IGNITION-ADVANCER-ROTOR-/163660231223
Slight reduction in top end power that in real life you will probably never notice.
CatalinU
« Reply #14 on: 11 December 2019, 04:36:30 pm »
Ok, will be getting one then. Thanks for the reply
ogri48
« Reply #15 on: 12 December 2019, 10:31:01 am »
yeah im running one now, I prefer it. along with the ivanising bike starts instantly too.
