Date: 11-05-26  Time: 21:33 pm
Author Topic: Rev Counter  (Read 2153 times)
Andy W
Rev Counter
« on: 15 April 2019, 08:24:20 pm »
Is there a simple way ('cos I'm a simpleton  :o ) to test whether or not the rev sender unit thingumajig is working?
Thanks!  :)
Re: Rev Counter
« Reply #1 on: 18 April 2019, 09:23:31 am »
What is the issue you have? Tacho signal wire goes directly to the ECU
PieEater
Re: Rev Counter
« Reply #2 on: 19 April 2019, 03:27:11 pm »
Andy has an aftermarket Speedo / Tacho unit which presumably is playing up  ;)
Andy W
Re: Rev Counter
« Reply #3 on: 19 April 2019, 05:07:46 pm »
Ah, hello! Yes, sorry about not responding....I have been dying of a serious bout of Man Flu...I have survived by the skin of my teeth & am just about alive!.........naturally I suffered in silence, as I kept telling everyone!  :rollin
Indeed as Mr Pie states, I have an aftermarket Koso digital dash & the rev readout has ceased suctioning. usually I believe these units pack up completely so I want to eliminate ant bike related issues foirst.
The Koso rev counter wire is simply soldered to the original feed wire - where I removed the OEM dashboard.
Re: Rev Counter
« Reply #4 on: 19 April 2019, 06:23:38 pm »
You could try moving the TPS. Mark the current position of the TPS, loosen it and move it left then right, tacho should react. The TPS is linked to the Ignitor which sends a signal to the tacho
Andy W
Re: Rev Counter
« Reply #5 on: 20 April 2019, 12:10:47 pm »
Thanks unfazed, I'll give that a try!  :)
