Date: 11-05-26  Time: 21:33 pm
Author Topic: Jack up kit  (Read 3270 times)
CatalinU
Jack up kit
« on: 30 March 2019, 09:14:58 pm »
I tried to look after thsi, don't if there's a discusion about this, couldn't find it. Did anyone do this modification? Is it worth it?
PieEater
Re: Jack up kit
« Reply #1 on: 31 March 2019, 09:32:56 am »
I would say it is very worthwhile, raising the rear puts more weight on the front of the bike which makes it turn in quicker to very noticeably improve handling, as does raising the forks through the yokes by ~15mm. The jack up kit also slightly adjusts the suspension geometry making the rear shock a little firmer which is also useful if you haven't replaced the rear shock yet. I have tried both 25mm & 50mm jack up kits on the Gen1 the 25mm works well with raising the forks through the yokes but the with the 50mm this puts too much weight on the front from my experience, so it is best to use the 50mm kit with the forks in the standard position.
CatalinU
Re: Jack up kit
« Reply #2 on: 31 March 2019, 12:52:06 pm »
Any recomendations on wich one should I buy? Found couple of them on fleebay.....
PieEater
Re: Jack up kit
« Reply #4 on: 01 April 2019, 08:24:03 pm »
Go with whatever you can find that fits your budget and height requirements they are not really visible when fitted so not a lot of point getting anything too fancy.
Stinka
Re: Jack up kit
« Reply #5 on: 01 April 2019, 08:58:31 pm »
I found the 2010 s1000rr shock raised my rear by 25mm, absolutely best £100 I’ve ever spent on a bike
Not tried raising forks yet, but might give it 10mm
CatalinU
Re: Jack up kit
« Reply #6 on: 02 April 2019, 02:14:01 pm »
How are you raising your forks? I was looking at mine, can-t see a way of rising the forks.... :(
CatalinU
Re: Jack up kit
« Reply #7 on: 02 April 2019, 02:30:29 pm »
That's the cheapest I could find
