Date: 28-03-26  Time: 09:39 am
Author Topic: Old measuring equipment  (Read 4325 times)
« on: 18 March 2019, 12:14:54 am »
I'd like to get some measuring equipment for using on bike engines. There's a lot of old used Mitutoyo micrometers and the likes for sale on ebay. My question for anyone who's experienced using measuring equipment is, would it be a waste of money buying old measuring equipment since you don't know how well it's been looked after or does good quality measuring equipment generally stay in spec? I was thinking about buying an old set of micrometers and then getting them checked with slip gauges. Is that a waste of money? Do you need new ones for checking engines?
coffee
Re: Old measuring equipment
« Reply #1 on: 18 March 2019, 05:32:37 pm »
What are you going to measure? you lost me after Mitutoyo micrometers, :lol is this for rebuilding engines or checking tolerances ? slip gauges?drrrr my brain's froze, :lol
agricola
« Reply #2 on: 18 March 2019, 06:02:48 pm »
Micrometers are adjustable, they used to come with a small c type tool for adjusting. They only really go out of adjustment when they are used a G clamps (overtightened on the object being measured). To put it in context, I've a set of mics from 0-25mm all the wat up to 150mm, and an internal with all of the various anvils. Never used any of them since I retired from work 3 years ago, and likely never will. What I di use, is the digital caliper, fairly regularly. You can get them for around a tenner form the likes if Lidl and Aldi. Easier to read, cheap the replace, and I would have thought more than adequate for 99.9% of bike maintenance. As for slip gauges, last time I saw a set for sale, they were very expensive.
Digital caliper is the way to go
coffee
« Reply #3 on: 18 March 2019, 06:15:50 pm »
Yep,digital caliper,never without one. :thumbup
« Reply #4 on: 18 March 2019, 06:40:58 pm »
Got all of them, so spoilt for choice. My non digital verniers get used most often though.
Rob R
« Reply #5 on: 18 March 2019, 09:27:12 pm »
I've got drawers full of of measuring equipment including a set of Starrett imperial mics from 0- 10 inch, set of Mitutoyo metric mics from 0-250mm, and a almost unused Mitutoyo digital caliper, but like agricola I tend to use a Lidl digital caliper that cost less than a tenner!
« Reply #6 on: 18 March 2019, 09:42:01 pm »
Like others, I still have my old Micrometers, Verniers etc from 30  yrs ago but I look after them. As said by Agricola, the micrometer will be ok if it hasn't been used as a G clamp...like wise the verniers will be ok as long as them haven't been used as a crowbar. The problem is you won't know how 2nd hand units have been used. Find an old boy who's having a clear out and you should be fine. Apart from that I wouldn't buy 2nd's to use as a true measurement. Just my 2p...
« Reply #7 on: 18 March 2019, 11:16:32 pm »
Still got my imperial More & Wrights of Sheffield Mic, and my Vernier Gauges, agrees with earlier comment the vernier gauge is the most usfull one unless you working down to I thou of an inch, a piece of normal printer paper is 4.5 thou thick, just used mic on it.
« Reply #8 on: 18 March 2019, 11:21:35 pm »
Just noticed it needs an oily rag rubbing over it, probably the second time its been out of the box for about 20 years
coffee
« Reply #9 on: 19 March 2019, 12:00:48 am »
You lot are really clever foccers. :eek
agricola
« Reply #10 on: 19 March 2019, 10:23:09 am »
I suppose I should consider making a bit of cash and selling mine, but to be honest, I dont think they are worth much these days. Guess Ill follow Tommy and give em a good clean, then put them back again
« Reply #11 on: 20 March 2019, 08:04:41 pm »
It would be interesting to measure some slip gauges and see if it is still accurate after all those years
« Reply #12 on: 20 March 2019, 08:08:26 pm »
I'd hang onto it. It's nice to have a tool that's real quality. Most tools are made to be thrown away now
« Reply #13 on: 20 March 2019, 08:12:10 pm »
I'll keep a look out for a well cared for set. Engineers generally look after their equipment so with a bit of patience I should be able to find a good set.
« Reply #14 on: 20 March 2019, 08:20:55 pm »
Mitutoyo is a company that makes top quality measuring equipment https://www.mitutoyo.co.uk/en_gb/
Slip gauges are precision blocks that you check you measuring equipment against. A tool maker or engineer that does fine measurements would have a set of slip gauges to check the accuracy of his measuring tool against https://en.wikipedia.org/wiki/Gauge_block
If you look through the engine section of the manual it shows what you'd be measuring. You could measure most things in an engine with a set of micrometers, a set of bore gauges, a dial indicator and plastigauge
« Reply #15 on: 20 March 2019, 08:55:16 pm »
Liking this one for starters.....in it's original case (always a plus) with tag and from up North where most engineering was done.
https://www.ebay.co.uk/itm/Old-Moore-and-Wright-Micrometer-No961-Cased/192853930273?hash=item2ce6fd7121:g:4aEAAOSwYu1chi0b
« Reply #16 on: 20 March 2019, 09:48:07 pm »
That's a nice one but the bike manual is all in metric so I'd be going for a metric one.
YamFazFan
« Reply #17 on: 15 September 2019, 02:29:21 pm »
Found these at the local boot sale this morning to go with my old M&W metric micrometer. Bargain at 50p each :) ....
steve 10562cc
« Reply #18 on: 15 September 2019, 02:47:48 pm »
Being a Brickie and just out my time I was setting out an extension to very posh house I asked the gaffer how accurate I had to be, the answer  "Just go to the right address"
ogri48
« Reply #19 on: 16 September 2019, 08:36:30 pm »
 :lol :lol :lol :lol aint it the truth. You ever jumped on someone elses work after thry've been sacked and found theres a pig in the brickwork mate? I had it once on a garage base. No windows so no chance of losing it. told the customer,  (An Asian fellow) and he said , just take it up regardless. I said 'no thanks...' ;)
YamFazFan
« Reply #21 on: 08 December 2019, 08:18:12 pm »
Another recent car boot sale bargain. 'The Modern Motor Engineer'. First published 1927. This reprint 1959. Complete set comprising 5 volumes, beautifully illustrated. £5 the lot.
