Date: 23-03-26  Time: 06:34 am
Author Topic: bike won't start!  (Read 3866 times)
celticdog
bike won't start!
« on: 11 March 2019, 08:35:19 am »
Ok so I got up this morning to go to work and the bike won't start!  :wall
Over the weekend and last night we've had rain, sleet and hailstones so I'm assuming water has got in somewhere. (The bike lives outside in my garden).
Electrics are working, the bike turns over strongly but doesn't kick into life. Tried with the kickstand up in case it's the switch.
Sprayed isopropyl alcohol on the plugs, up the leads and on the connector at the back of the coils, still not working!
Any Ideas on what to do next are welcome, I need to get the thing going as I've a big journey to do tomorrow!
Re: bike won't start!
« Reply #1 on: 11 March 2019, 09:13:29 am »
I had an intermittent starting problem for ages, which would involve backfiring and all sorts of fun and games.
Tried loads of things, including changing parts, etc. Same thing, cranking over strongly, battery was in a very good and charged state.
Then the other day it happened again but then when i was riding the engine just cut out. Got it started again soon after but this now gave me a different angle to investigate.
It was then hinted that it could be an ignition switch problem.
A few months ago i'd put a bit of WD40 on my key as the switch felt a bit sticky, but years ago i remember using graphite on the switch to do a similar job.
So apparently, over time the switch can get clogged up with dirt, congealed grease, or basically whatever you've chosen to shove in it over time to give it a bit of a lube. This will then make the contacts intermittent. I reckon rain going down the key hole can move shit about a bit, causing the random misbehaving.
Not feeling overly hopeful, i then drowned the ignition barrel down the key hole in Isopropyl Contact Cleaner spray, using the key as well so it got everywhere possible, and it was an instant revelation.
Bike starts strongly first time on the button now, and even feels better in running as well.  :)
Certainly worth a go, even more so as you have the right spray to hand.
« Reply #2 on: 11 March 2019, 09:47:11 am »
Might wanna spray WD40 around the plug and HT lead area now, rather than IPA.
celticdog
« Reply #3 on: 11 March 2019, 06:39:40 pm »
Cheers darrsi, worth a try. It was doing the backfiring thing but just not springing into  life. I've got to charge the battery anywahy so i'll give the barrel the once over to see if I can get her to start.
His Dudeness
« Reply #4 on: 11 March 2019, 06:51:58 pm »
If it's back firing it must be getting some bit of spark. Maybe rain water has got in your tank from a blocked drain at the filler neck or the drain pipe in the tank could be rusted out and the water is getting in the tank and it's in the carbs now so the bike can't start. You could try draining the carbs bowls and see if it starts after that. Also open the tank carefully have a look in around the filler cap and in the bottom of the tank for water.
BBROWN1664
« Reply #5 on: 11 March 2019, 06:52:19 pm »
Did you try using the choke?
ogri48
« Reply #6 on: 11 March 2019, 07:38:44 pm »
bit of brake cleaner in the air inlet will tell you if its sparking ok mate. if it starts and runs briefly with a squirt of that its gonna be a fuel problem
« Reply #7 on: 11 March 2019, 07:59:02 pm »
I did all your suggestions over a long period of time, several times, because they are the places that all make sense to try out!
celticdog
« Reply #8 on: 11 March 2019, 08:49:44 pm »
Cheers Gents. :)
Had another go this evening with trying to clean out the ignition barrel. Not had much luck, now got the battery back on charge and praying that it stays dry tonight. Will have a try tomorrow morning, if no joy then it's back to the train with northern rail unfortunately. They really are the worst rail operator going- dreadful. I'm inclined to think it's water that's caused the problem somewhere as she was running sweet beforehand. Hey ho plenty to keep me busy at the weekend.
ogri48
« Reply #9 on: 11 March 2019, 08:52:12 pm »
best of luck with it dude
coffee
« Reply #10 on: 11 March 2019, 09:12:09 pm »
Can you get it indoors for a while and keep a hair dryer on it ? might sound a bit daft but I had an old van which would do this at the slightest bit of damp and I'd put a hair dryer pointed at the engine for a time and it would do the trick!
Dudeofrude
« Reply #11 on: 11 March 2019, 09:15:00 pm »
A decent waterproof cover may be a wise investment too 👍
« Reply #12 on: 11 March 2019, 09:24:30 pm »
If you suspect water in the tank, or just want to rule it out, put 300ml of 99% IPA in a full tank of fuel, if possible the 99ron stuff from a Shell garage, and any water will bind with it and burn off as fuel.
Grahamm
  • Global Moderator
« Reply #13 on: 12 March 2019, 12:38:07 am »
India Pale Ale...? :pokefun
Robbie8666
« Reply #14 on: 12 March 2019, 07:48:50 am »
ogri48
« Reply #15 on: 12 March 2019, 09:41:28 am »
lol IPA was 24p a pint when I started "pubbing" in 1977. eight pints for two quid. and people say the seventies were harsh... :lol
slappy
« Reply #16 on: 12 March 2019, 05:11:39 pm »
1973,  a pint of mild in the Eldon was 11p,  i was 16 ,  truly the good old days :D
I think we might have gone a bit off topic .
ogri48
« Reply #17 on: 12 March 2019, 07:14:05 pm »
 :lol :lol :lol
ogri48
« Reply #18 on: 12 March 2019, 07:14:51 pm »
did it start welshwoofer? ;)
