Date: 25-05-26  Time: 10:18 am
Author Topic: exup spacer missing  (Read 4314 times)
kerb
exup spacer missing
« on: 07 April 2012, 11:59:33 am »
Hi All
looking for a bit of help , i recently bought 03  fazer thou
so i was getting the error code for exup valve when ignition turned on ( rev counter going to 700rpm)
so found that exup valve was seized
so i striped it down and  greased it all up now moving freely with hand
but when i tightened up all bolts to torque setting found that valve was very hard to move
so i took it out again i found that the spacer was missing
( see spacer on this pic, red arrow pointing to it in pic r/h top )
http://www.cartestsoftware.com/fz1/images/exupmaintenance05.jpg
and first part on left in this pic http://www.cartestsoftware.com/fz1/images/exupmaintenance04.jpg
so i want to make a spacer for it
so my Questions are
is this spacer the same diamater as the bushing thats inside it
what i mean is , is the outer diamater larger than the bushing thats inside it
( this bushin doesnt normaly come out when valave removed its not in any pics
thanks for any info kerb
kerb
Re: exup spacer missing
« Reply #1 on: 07 April 2012, 12:05:08 pm »
heres a parts diagram
http://www.oemmotorparts.com/oem5.asp?M=Yamaha&T=FZS FAZER  1000&Y=2003&L=YA-FZS-FAZER-1000&O=EXHAUST SYSTEM&F=YA-FZS-FAZER-1000_al&L2=YA-FZS-FAZER-1000_al
the inside bushing is no.9
and spacer im missing is no.13
but its about 50 quid postd to me
mcyoungy
« Reply #2 on: 07 April 2012, 12:09:52 pm »
kerb
« Reply #3 on: 07 April 2012, 05:16:12 pm »
http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?PageiD=12&modelID=9753&m=YAMAHA+FZS1000+FAZER+2002++2002+EXHAUST&uID=0
can't read the drawing in your post but you can buy the part online here.
thas the part alright , but its still 35 pound posted to me but thanks for info
kerb
« Reply #4 on: 10 April 2012, 02:26:27 pm »
bump  :D
Smokinjoe
« Reply #5 on: 10 April 2012, 06:14:24 pm »
I've just stripped mine out this afternoon  :)
The spacer is 15mm outside diameter and 4mm thick and is made from stainless I think as its not magnetic!
Check carefully inside the exhaust because the first time I stripped mine out I had the same thing and thought it was missing but on closer inspection I found it inside. It had dropped off when I pulled the valve out.
After I had found it I struggled a bit to get it back and that is how I know its not magnetic!
If you don't find it I would check the diagram again I think its the bush that's £35 not the spacer!
Good luck!
kerb
« Reply #6 on: 10 April 2012, 11:19:54 pm »
Good luck!
cheers Joe that's a great help
i will check this out tomorrow
the reason the spacer is 35 pounds to me is cause I'm including postage to ireland
as you  say maybe its inside cause i just stuck a long magnet in there ( thinkin it was magnetic )
i will report back
cheers  kerb
