Date: 25-04-26  Time: 03:40 am
Author Topic: Coolant dribble.....  (Read 1920 times)
nedworthy
« on: 20 December 2018, 11:10:45 am »
Just started to drain coolant and it’s barely dribbling out , no gush as I’d expect. Does this suggest a blockage somewhere ?
Re: Coolant dribble.....
« Reply #1 on: 20 December 2018, 11:54:18 am »
Did you take the filler cap off.Take it off and put the bucket 2 feet away from the drain hole  ;) you have been warned
It should look like this
« Reply #2 on: 20 December 2018, 11:58:30 am »
« Reply #3 on: 20 December 2018, 12:26:55 pm »
Should really clean the system out with Radflush before refilling, but probably too late now.
« Reply #4 on: 20 December 2018, 02:20:44 pm »
Don't think he's got the old out yet
nedworthy
« Reply #5 on: 20 December 2018, 03:55:42 pm »
Yep did all the right things with caps etc - got up to a steady trickle  :z and eventually cleared, then gave a blast through with distilled water. Probably should have done Rad flush but things looked pretty clean so will do that next time ... thnkx peeps for comments
« Reply #6 on: 20 December 2018, 04:05:06 pm »
Looked clean???
It"s the scaling in and around the waterways, similar to a kettle, which you can't see that is what needs looking after.
Just makes sense to do it whenever you replace the coolant, to keep everything in good nick.
nedworthy
« Reply #7 on: 20 December 2018, 04:22:55 pm »
X ray vision  :eek ....... :)
