Date: 21-03-26  Time: 11:53 am
Author Topic: FZ1 Gen 2 - rear shock  (Read 2184 times)
FZ1obp
« on: 29 November 2018, 08:33:45 pm »
Off to the tip at the weekend - just checking that the old shock of the Gen 2 can't be rebuilt? The spring on it is grey/silver while the 2nd hand replacement I put on the bike about 2 years ago is yellow and a bit harder.
Looking in manual I didn't see any spring rate/color charts - any ideas?
Many thanks
Dudeofrude
Re: FZ1 Gen 2 - rear shock
« Reply #1 on: 29 November 2018, 11:22:12 pm »
The standard shock has a silver spring. As far as I'm aware the spring can be replaced on the standard shock, I just don't think they can be stripped and re-gassed like an aftermarket one
FZ1obp
« Reply #2 on: 30 November 2018, 08:56:59 am »
Great - thank you, off to the tip then after removing the spring.
Cheers!
NorthWestern
« Reply #3 on: 30 November 2018, 11:00:42 am »
You should be able to rebuild/regas the standard shock.  I have done it to the std Gen 1 shock, its not a problem.  Any suspension place would be able to do it really.
« Reply #4 on: 30 November 2018, 11:30:52 am »
If you give All Bike Engineering a call on 0208 8589052, they'll tell you straight away if it's rebuildable or not.
FZ1obp
« Reply #5 on: 03 December 2018, 08:03:11 am »
Thanks for the guidance - all sorted now
