Date: 07-05-26  Time: 16:30 pm
Author Topic: Exhaust identity  (Read 8638 times)
deeteefifty
Exhaust identity
« on: 11 September 2018, 05:33:18 pm »
This'll be a standard pub quiz question. Can anyone identify the makers of these exhausts. There is a standard silencer on and it's blowing a bit, the previous owner put some exhaust wrap around the silencer front pipe section for the MOT. If I need to get a new silencer I'd prefer to match it to the front pipes if there's no decent original Yamaha ones around.
daviee
  • Guest
Re: Exhaust identity
« Reply #1 on: 11 September 2018, 07:23:11 pm »
could be motad as they are not black widow or delkavic or lextec as their is no webbing at the collector
bandit
« Reply #2 on: 11 September 2018, 08:10:10 pm »
Their not Motad, as there's no balance pipes between the down pipes. Older Black widows didn't have springs at the collector but new ones do so my guess is Black widow.
As far as I'am aware all aftermarket end cans with the correct link pipe should slide onto your aftermarket down pipes.
deeteefifty
« Reply #3 on: 11 September 2018, 09:17:54 pm »
Thanks daviee and bandit, I'm going cross eyed looking for same type
« Reply #4 on: 12 September 2018, 08:39:21 am »
They look the same as mine, but i have no idea what they are either  :lol
As said though, it's mainly about the link pipe, not all end cans have the same diameter. I have a Quill and a Moto GP can that need different size link pipes to fit the downpipes.
http://foc-u.co.uk/index.php/topic,8580.25.html
BBROWN1664
« Reply #5 on: 12 September 2018, 09:42:51 am »
TBH, all downpipes will fit. They are all designed to replace the original downpipes using the standard can.
BBROWN1664
« Reply #6 on: 12 September 2018, 09:44:10 am »
They could be the original pipes. They are not Delkevic.
« Reply #7 on: 12 September 2018, 10:40:47 am »
Weren't all original pipes black?
BBROWN1664
« Reply #8 on: 12 September 2018, 03:58:35 pm »
Maybe. I thought the last ones were unpainted stainless but may be wrong. Given the last ones are over 15 years old now it is unlikely to be original.
deeteefifty
« Reply #9 on: 12 September 2018, 04:51:37 pm »
Thanks darrsi and bbrown1664. The pipes are all welded with no separate sections, I'll give them a proper clean up to see if there are any faded markings. The outlet diameter is 45mm and they're in sound condition, if the silencer is beyond repair at least I have the outlet size to go off for replacement. The combination of the pipes and silencer has the engine running nice and smooth, very quiet (maybe a bit too quiet) but I wouldn't want to upset the balance for a bit noise.
bandit
« Reply #10 on: 12 September 2018, 06:38:15 pm »
deeteefifty, changing the silencer & link pipe won't effect balance only new down pipes will, as for the noise just make sure you by a road legal one with a removable baffle (db eater) which when removed can alter the noise level. Smile
https://www.blackwidowexhausts.co.uk/fzs-600-304-c.asp
deeteefifty
« Reply #11 on: 12 September 2018, 07:30:08 pm »
Ta bandit, and for the link too, their site is giving me silencer overload.  :eek
bandit
« Reply #12 on: 12 September 2018, 09:38:29 pm »
Just remember the shorter the silencer the noisier it will be,more so with the baffle removed, if you like the sound of the standard one get one of about the same length/diameter & when you remove the baffle it won't be to loud.
« Reply #13 on: 12 September 2018, 09:52:17 pm »
My Moto GP end can is noisy as feck, but legal with the baffle in.
Take the baffle out and the bike runs poorly, and will wake the dead.
I much prefer the subtle rumble of the Quill, but it still has a lovely roar when you give the bike some welly.
Dynspud
« Reply #14 on: 13 September 2018, 08:58:59 am »
I stuck a Pipe Werx stainless, standard length, on my Foxeye and it looks & sounds superb and that's with the baffle in.
http://www.pipewerx.com/
Good quality product at a fair price.
deeteefifty
« Reply #15 on: 13 September 2018, 03:31:51 pm »
Thanks everyone. I got a reply from Black widow exhausts. They said it's not one of theirs as they've always had a seperate link pipe, mine doesn't. A bit more cleaning uncovered what looks like black paint (but could be burnt on oil/muck). Maybe they are originals that have been unblacked🤔
« Reply #16 on: 13 September 2018, 04:01:50 pm »
No, originals are mild steel, not stainless.
Jules-C
« Reply #17 on: 13 September 2018, 04:14:45 pm »
And originals had the balance pipes between downpipes.
YamFazFan
« Reply #18 on: 13 September 2018, 04:24:06 pm »
Stainless painted black on the Foxeyes.
bandit
« Reply #19 on: 13 September 2018, 04:35:50 pm »
Nope steel painted on foxeyes same as boxeye, only stainless on FZ6.
deeteefifty, can you post a picture of the exhaust side view, end can (silencer) to where the pipe goes under the frame, have not seen aftermarket set that doesn't need a link pipe only original which they ain't.
deeteefifty
« Reply #20 on: 13 September 2018, 05:58:38 pm »
As requested bandit.
bandit
« Reply #21 on: 13 September 2018, 08:18:14 pm »
Still no wiser on the the down pipes & black widow are talking out of their a**e , because when you remove the jubilee style black clamp on the original  & remove the silencer the link pipe then attaches to that end without the gauze gasket inside & the other connects to the silencer.
Look at this picture, where the black downpipes end is where the link pipe connects & then connects to the silencer the original silencer comes with the link pipe & silencer as one piece, hope this helps.
https://www.gumtree.com/p/yamaha-motorbikes/yamaha-fazer-600-1999-t-reg-not-bandit-hornet-streetfighter-cheap-bike/1274646165
YamFazFan
« Reply #22 on: 13 September 2018, 08:59:41 pm »
I read it ages ago here in this Bennetts buyers guide in the 'Any Updates?' section. Must be bad info.
https://www.bennetts.co.uk/bikesocial/reviews/bikes/yamaha/yamaha-fzs600-fazer-1998-2003-buyers-guide
My original downpipes are still like new with all the factory paint still attached.
« Reply #23 on: 13 September 2018, 09:17:49 pm »
Looks like Lextex Stainless Downpipes
deeteefifty
« Reply #24 on: 13 September 2018, 10:29:39 pm »
Thanks again everyone. Unfazed it does look close to a Lextek.
