Date: 08-05-26  Time: 08:27 am
Author Topic: do I need to replace front sprocket nut  (Read 1916 times)
mobile mouse
« on: 15 July 2018, 11:41:01 pm »
Hi,
Bike fitted with 12mm front sprocket.
If and when I need to change chain and sprockets front/rear.
Do I need to replace the present 12mm nut or can I re-use present nut....
bandit
Re: do I need to replace front sprocket nut
« Reply #1 on: 16 July 2018, 07:49:20 am »
You can reuse the 12mm nut if threads are ok,just make sure the washer is good to bend to lock the nut.
If required,
https://www.wemoto.com/bikes/yamaha/fzs_600_fazer/98-99/picture/front_sprocket_retaining_nut_kit_oem/
« Reply #2 on: 16 July 2018, 03:06:25 pm »
Actual recommended torque setting for the newer 12mm nut is 90Nm, but a few of us thought that might be a bit risky due to the thread issues so only used 80Nm with a bit of Loctite, as well as the washer.
9mm nut was 70Nm if memory serves me correctly.
