Date: 07-05-26  Time: 19:32 pm
Author Topic: Indicator relay  (Read 2661 times)
Valley boi
Indicator relay
« on: 02 July 2018, 05:39:22 pm »
Where is it as got an mot and my blinkers are flashing too fast now and again but there's no led bulbs on it.
Valley boi
Re: Indicator relay
« Reply #1 on: 02 July 2018, 06:04:06 pm »
Just noticed that it only happens when its running it's fine with the engine off.
Re: Indicator relay
« Reply #2 on: 02 July 2018, 06:05:34 pm »
Check all other bulbs, normally happens when one is faulty.
bandit
Re: Indicator relay
« Reply #3 on: 02 July 2018, 08:38:57 pm »
It's behind the left hand black side panel. :)
Valley boi
Re: Indicator relay
« Reply #4 on: 02 July 2018, 09:02:57 pm »
Yes I did find it but I'm puzzled by why it only happens when its running  :\
Hugh Mungus
Re: Indicator relay
« Reply #5 on: 02 July 2018, 10:17:13 pm »
Just replace it - No idea why it does it when it's running but it's obviously not working right.
I fitted an adjustable flash rate relay which was cheap cos I waited 4 weeks for it to arrive from China but there are some in the UK, just a bit dearer. You might have to make up a couple of wires with spade end connectors as mine didn't fit directly onto my Fazer 1000.
Re: Indicator relay
« Reply #6 on: 03 July 2018, 12:39:02 am »
Possibly regulator
celticdog
Re: Indicator relay
« Reply #7 on: 03 July 2018, 07:30:21 am »
I had the same problem when I first got my Fazer. Turns out bulbs with the wrong wattage where fitted in the aftermarket blinkers.
New bulbs of the correct rating solved the problem. With bayonet bulbs, anything other than 21W will affect the blinking rate.
BBROWN1664
Re: Indicator relay
« Reply #8 on: 03 July 2018, 08:40:08 am »
:agree
Flashing too fast when the engine is running is down to the slightly higher voltage when using the incorrect wattage bulb. It could be a bulb that has failed and "re-made" itself.
you might be able to pin it down to one side btu its an easy and cheap job to replace all 4. The relay is behind the left side panel. You should replace that with an LED specific one if you have fitted LED bulbs
