Date: 11-05-26  Time: 21:33 pm
Author Topic: Exup cables  (Read 2425 times)
Mustang
Exup cables
« on: 18 June 2018, 09:08:23 pm »
just snapped one of them, £39 a set on wemoto. £117 on fowlers, Jesus.
NorthWestern
Re: Exup cables
« Reply #1 on: 19 June 2018, 06:04:32 am »
I used one of those venhill exup rebuild kits. IIrc it was only a tenner, worked like a charm
nordboy
Re: Exup cables
« Reply #2 on: 19 June 2018, 06:52:48 am »
The wemoto ones are fine, Amazingly easy to fit (does help having an extra hand though ;) ). I replaced mine and I have very little mechanical skill.
Re: Exup cables
« Reply #3 on: 19 June 2018, 08:01:24 am »
 :agree
Dustydes
Re: Exup cables
« Reply #4 on: 19 June 2018, 05:33:46 pm »
Did mine with nipples and 1.5mm Bowden cable off of ebay. Easy
Mustang
Re: Exup cables
« Reply #5 on: 20 June 2018, 08:41:27 am »
Sadly it’s not the cable that snapped but the adjuster. When the engine is off I found the exup cam doesn’t line up over the locking hole. It’s supposed to right? But I found I couldn’t get enough slack with the adjuster so I gave it another turn and it sheared off. Is it supposed to line up when you turn the engine on?
Re: Exup cables
« Reply #6 on: 20 June 2018, 10:35:52 am »
It will only line up when you switch the ignition on or turn off the engine with the kill switch. Adjustment is made on the cables under the tank on the right hand  side
Mustang
Re: Exup cables
« Reply #7 on: 20 June 2018, 02:19:07 pm »
Airbox replaced, carbs cleaned and refitted, newer carb rubbers, carbs balanced, new exup cables.
[size=78%][/size]
