Date: 02-05-26  Time: 21:10 pm
Author Topic: Changed spark plugs then raidator burst  (Read 2264 times)
Just a Faze im in
« on: 14 May 2018, 05:29:09 pm »
Hello all,
I changed my spark plugs for some CR8EIX iridium plugs and the bike seemed a lot quicker, great improvement.
However after 20 miles the radiator developed a hole and sprayed coolant everywhere.  I'm waiting on a replacement radiator but do you think it could be linked to the change of plugs?
redmandan
Re: Changed spark plugs then raidator burst
« Reply #1 on: 14 May 2018, 08:04:57 pm »
Without knowing more I would say no. They're  entirely different circuits. There is a chance that the engine was maybe running a bit hotter with the new plugs but it's not the first place I would look. Was it the first good run in a while? Where is the damage on the radiator? Maybe a stone or something flew into it at speed.
Good luck with fitting the new radiator.
« Reply #2 on: 14 May 2018, 08:34:00 pm »
Won't be related to the plugs, just a coincidence.
Once the new red is fitting flush the system with Radflush before putting coolant in, you may have had a blocked system that may have contributed towards it, although there could be other reasons of course.
Just a Faze im in
« Reply #3 on: 14 May 2018, 08:35:54 pm »
Thanks, yeah I didn't think so too. If it was running hotter/ too hot it should just boil out the overflow. I agree , prob just a stone and a coincidence.
Just a Faze im in
« Reply #4 on: 14 May 2018, 08:38:44 pm »
I had to drive it a good mile with no coolant to get it somewhere safe to park so hopefully I haven't cooked the head gasket as well.  The fan was coming on for most the journey
ponkster
« Reply #5 on: 15 May 2018, 09:23:20 am »
Only related to the plugs if you wacked the radiator taking the plugs out!
adasilva
« Reply #6 on: 15 May 2018, 05:27:16 pm »
Most likely you had a gravel from the wheel which hit the radiator. It happened with a friend of mine.
