Date: 07-05-26  Time: 08:56 am
Author Topic: borken caliper bleed nipple  (Read 3450 times)
psyfi_1
« on: 08 May 2018, 02:44:56 pm »
broken caliper bleed nipple  any suggestions
andybesy
Re: borken caliper bleed nipple
« Reply #1 on: 08 May 2018, 03:23:58 pm »
Has it sheared or just rounded?
If it's sheared, is it flush?
There're quite soft, so you may be able to hammer something like a star drive bit in to it, then turn it using that? Probably best to remove the caliper from the bike first.
A picture would be useful.
Andy
andybesy
« Reply #2 on: 08 May 2018, 03:25:45 pm »
Also, was it sheared due to not wanting to come undone, or over-tightening?
If it's just been over tightened then it should come out okay if you can only get a grip on it, but if it sheared when you tried to undo it then presumably it's corroded in there, which can be harder.
psyfi_1
« Reply #3 on: 08 May 2018, 03:35:31 pm »
no its sheared flat to the caliper............ sucks balls
BBROWN1664
« Reply #4 on: 08 May 2018, 04:54:57 pm »
get a small ez-out and wind it in gently. The nipple should come out.
psyfi_1
« Reply #5 on: 08 May 2018, 05:44:09 pm »
okay i will buy one tonight and try it out.........
daviee
  • Guest
« Reply #6 on: 08 May 2018, 06:03:07 pm »
you can get away with out it so wouldnt worry to much about it worst case buy a banjo bolt with a bleed nipple on it
Trebus
« Reply #7 on: 08 May 2018, 08:26:24 pm »
For next time, a bit of heat can help wonders. And some alu anti seize paste smeared on the threads will stop them getting stuck. I find car rear slave cylinders to be the worst for it but again, heat normally helps shift them.
psyfi_1
« Reply #8 on: 14 May 2018, 01:58:47 am »
can you heli coil a caliper
Gnasher
« Reply #9 on: 15 May 2018, 10:03:53 pm »
Did it snap off because of something you did of was it like that when you got the bike?
psyfi_1
« Reply #10 on: 26 May 2018, 02:08:24 pm »
it snapped i turn it a bit to forcefully like a tit
Gnasher
« Reply #11 on: 26 May 2018, 02:24:22 pm »
Was you doing it up or undoing it?
psyfi_1
« Reply #12 on: 26 May 2018, 02:28:18 pm »
undoing
Gnasher
« Reply #13 on: 26 May 2018, 02:53:08 pm »
undoing
Ok it's very likely the nipple was over tightened by whomever work on the caliper before you.  As mentioned above an ez out will normally work, when I've done them I use a bit of heat on the caliper body around the nipple just a butane gas torch for a about 30 seconds and out they come.
You only need 6Nm or 4.5 Ft- lbs.
