Date: 13-05-26  Time: 14:48 pm
Author Topic: Gen 2 radiator side cover bolt size?  (Read 1864 times)
Dudeofrude
« on: 07 May 2018, 09:07:03 pm »
As per title, looking to replace all 4 bolts in the radiator side covers ( number 46 on this fowlers diagram) min are currently all different 🤔
Anyone know the size and length?
I may sound stupid here but I have no idea how to work it out using the current bolt??
robbo
Re: Gen 2 radiator side cover bolt size?
« Reply #1 on: 07 May 2018, 09:43:58 pm »
If you've got access to a set of vernier calipers, you just need to measure the length from under the head in mm and the thickness as in diameter of the threaded section. If the diameter was for example 6mm, then you'd need an M6 x the measured length.
Dudeofrude
« Reply #2 on: 07 May 2018, 09:49:43 pm »
Spot on Robbo thanks 👌
