Date: 03-05-26  Time: 03:47 am
Author Topic: Carb diaphram  (Read 4419 times)
reaper1064
Carb diaphram
« on: 03 May 2018, 10:10:33 pm »
Besides Suttons, who are not taking orders at the moment, does anyone know where I can get new carb diaphragms
Disorderlypunk
Re: Carb diaphram
« Reply #1 on: 03 May 2018, 11:05:28 pm »
fowlers are back order aswell
if you google the part number 5DM-14940-00
you will find it appears on a lot of other bikes, and even some boat engines
reaper1064
Re: Carb diaphram
« Reply #2 on: 03 May 2018, 11:11:24 pm »
Cheers mate.
tommyardin
Re: Carb diaphram
« Reply #3 on: 03 May 2018, 11:23:18 pm »
Well done punk that was quick and friendly service
Disorderlypunk
Re: Carb diaphram
« Reply #4 on: 03 May 2018, 11:27:07 pm »
thats what she said !!!
Disorderlypunk
Re: Carb diaphram
« Reply #5 on: 03 May 2018, 11:31:07 pm »
if you only need one then you might get away with a used one
https://www.ebay.co.uk/itm/YAMAHA-FAZER-600-FZS600-5DM-98-03-CARB-CARBURETOR-CARBURETTOR-DIAPHRAGM-X1/173231399571?hash=item2855656293:g:OKwAAOSwwChatBs7
£14 is better than £30-40
he seems to have stripped down a set of carbs to try and make the most cash he can so if you need any other parts it might be worth making him a bulk deal and knocking about 35% off everything
reaper1064
Re: Carb diaphram
« Reply #6 on: 04 May 2018, 08:15:22 am »
Thanks for that mate, yes only need the one at the moment. Only changing it as a proccess of elimination on a slight running issue. thanks again for your help.
Wootan
Re: Carb diaphram
« Reply #7 on: 06 May 2018, 10:42:37 am »
Where are you based, I have an a spare set of carbs in bits. I'm sure one of the will be fine, you're welcome to it for free as I was just gonna bin them away.
Disorderlypunk
Re: Carb diaphram
« Reply #8 on: 06 May 2018, 12:18:06 pm »
any chance you want to sell me the float bowl drain screws (if you pm me an email i can send you a few bob through ebay)
i think one of mine is leaking but not sure
Wootan
Re: Carb diaphram
« Reply #9 on: 06 May 2018, 07:31:41 pm »
If I can get them out you're welcome to them. I'll have look in the morning and come back to you
Disorderlypunk
Re: Carb diaphram
« Reply #10 on: 06 May 2018, 08:01:23 pm »
cheers bud - even my collection of spares cant help in this one - my fazer parts are a bit thin on the ground
-unless someone needs an airbox or clocks as thats all that is usable here
reaper1064
Re: Carb diaphram
« Reply #11 on: 06 May 2018, 08:05:31 pm »
Hi Wooten cheers for that I am at castle donington. I can reimburse the postage costs. just let me know..
Wootan
Re: Carb diaphram
« Reply #12 on: 06 May 2018, 09:02:22 pm »
I've had a quick look at drain screws and they might be tricky to shift. I scrapped the original carbs as most of the screws were toast. I've given them a good soaking so I'll let you know how I get on. Diaphrams should be fine, I'll get everything I can off tomorrow and let you both know.
Disorderlypunk
Re: Carb diaphram
« Reply #13 on: 06 May 2018, 09:19:15 pm »
if they are stuck i will just give you extra to ship whatever is there - i have the time and the patience to let stuff like that soak for days (and some tricks using the oven when the house is empty) - i never like to see things go in a bin that might be usable to someone lol
foc-u spares department lol
reaper1064
Re: Carb diaphram
« Reply #14 on: 06 May 2018, 09:22:24 pm »
Cheers mate
Wootan
Re: Carb diaphram
« Reply #15 on: 07 May 2018, 11:21:05 am »
I've got a diaphram out no problem.Drain screws aren't going to be so easy. Pic attached
Disorderlypunk
Re: Carb diaphram
« Reply #16 on: 07 May 2018, 11:43:50 am »
ahh they have had some life - i have a feeling those are not going to be easy to shift
or the float bowl screws annoyingly
Wootan
Re: Carb diaphram
« Reply #17 on: 07 May 2018, 12:09:11 pm »
It was sat next to sea for a few years. Only done 14000 miles. I've nearly finished a full restoration.
