Date: 18-03-26  Time: 02:17 am
Author Topic: Replacement cooling pipes  (Read 7783 times)
Freza
« on: 20 April 2018, 11:32:33 pm »
http://foc-u.co.uk/index.php/topic,24057.0.html
So, my cooling pipes are gone :(
My mechanic tried to save them by welding them, but it didn't help.
They have been eaten out from the inside. He says it's because they're made of iron.
I tried finding them online, but no luck so far.
I'd appreciate it if you have any ideas where I could find them.
Thanks!
Re: Replacement cooling pipes
« Reply #1 on: 21 April 2018, 07:27:38 am »
Am i missing something here, they're designed to be in constant contact with water?
Try a free online motorcycle breakers search.
I don't recall ANYONE having this issue before though?
« Reply #2 on: 21 April 2018, 08:50:53 am »
Plain water or weak coolent ?
Freza
« Reply #3 on: 21 April 2018, 09:29:42 am »
I don't know :/
What is motorcycle breakers search?
« Reply #4 on: 21 April 2018, 10:20:03 am »
I don't know :/
Tick the "email only" box otherwise you'll possibly get loads of phone calls.
http://www.bike-breakers.info/
« Reply #5 on: 21 April 2018, 10:25:53 am »
His bike would act like a kettle if the mixture was that weak. Rust would be the least of his problems.
« Reply #6 on: 21 April 2018, 11:32:48 am »
You can use water it won't boil because the cooling system is pressurised so the boiling point is raised but water corrodes metal and freezes at too high a temperature so you shouldn't use it on a road bike
« Reply #7 on: 21 April 2018, 11:38:24 am »
if you go track racing (road racing) you have to use water only - no coolant is allowed following acu regulations
water is one of the best coolants there is but unfortunatly for us it freezes and in some areas is full of crap
hard water areas should not fill coolant straight from tap thats one of the things that causes issues
« Reply #8 on: 21 April 2018, 11:45:20 am »
and if you dont know if you live in a hard water area
https://www.scaleguard.co.uk/hard-water-areas.html
« Reply #9 on: 21 April 2018, 12:07:36 pm »
So his issue stems from an incorrect/weak mix over time then?
Can't say i've ever used water on its own because it makes zero sense when coolant/antifreeze does what it says on the bottle.
« Reply #10 on: 21 April 2018, 12:32:42 pm »
it could be a weak mixture so the corrosion inhibiters are not strong enough yes
a catalyst to corrosion could also be caused by limescale which is caused by hard water in hot systems
-- from a central heating company --
The building blocks of limescale are calcium and magnesium.  Thus, one would think that limescale should have a white color.  Yet, limescale deposits are usually brown!  When limescale deposits build up, iron and oxidized iron particles get caught and are imbedded in the limescale.  Rust firmly attaches itself to your pipes, causing serious threats such as corrosion.
Freza
« Reply #11 on: 21 April 2018, 12:58:10 pm »
Just sent the inquiry to bike-breakers. Thanks.
Regarding the corrosion, the bike has been serviced by many mechanics for the past 15 years, I was relying on them so I didn't check if they all poured in antifreeze. I thought it's just a normal thing to do. :/
My current mechanic showed me the pipes, they are eaten from the inside, and T-pipe also broke so he had to weld it. Inside the pipes there was brown dirt that they had to clean, grease the tubes, change the clamps and pour in fresh antifreeze, but it looks like it didn't help, it still leaks :(
« Reply #12 on: 21 April 2018, 01:11:26 pm »
Coolant is one of the things that often gets over looked on a "full service". Sometimes you have to specifically ask for it to be changed. The Fazer has the fill point for the system under the tank so to check the condition of the fluid you have to move the fuel tank out of the way and I guess the mechanics didn't do that. If you leave it go too long it'll lose it's effectiveness at stopping corrosion and you'll get corrosion from the inside out like you said and when you do change it it'll come out looking like rusty water. If you have a look on ebay and type in "fazer 600 cooling" and you should find some good used pipes
« Reply #13 on: 21 April 2018, 01:13:02 pm »
i hope you kept them because if you have no luck finding some it might mean having some fabricated
problem will be finding someone willing to, custom car builders could (is they do custom rads) as could any firms that repair hydraulic machines as pipework is often damaged
« Reply #15 on: 21 April 2018, 01:15:10 pm »
Probably more likely it was from old coolant rather than too much water but the effect is the same corrosion!
Freza
« Reply #16 on: 21 April 2018, 01:18:11 pm »
I'm so pissed because of that.
Forecast for the whole week is sunny and I can't even find the damn pipes yet :(
https://www.ebay.co.uk/itm/yamaha-fazer-fzs600-1998-water-pipe-journal/232258174221?hash=item3613aa7d0d:g:HKUAAOSwTM5YuDED
Thanks, I'll have a look. Not sure what pipe this is.
Freza
« Reply #17 on: 21 April 2018, 01:29:15 pm »
I just asked my mechanic to send me pictures of my pipes while they were taken out, he took them before they reassembled them.
Only the T-pipe was already welded by him.
Take a look at this shit.
I don't know what they used for cooling, but this borderlines with sabotage attempt, I'm not far away from thinking one of them wanted to screw my bike up, just don't know which one.
« Reply #18 on: 21 April 2018, 01:59:19 pm »
That's a shame on such a clean bike. A set of used pipes off ebay should sort it out for not too much. You might want to change the thermostat and rad cap as well in case they are rusted.
Freza
« Reply #19 on: 21 April 2018, 02:05:33 pm »
Cap already changed, thermostat is next  :thumbup
« Reply #20 on: 21 April 2018, 02:14:16 pm »
Before you put new coolant back in after getting things sorted i would seriously advise using some RadFlush to give the internals a good clean up.
Freza
« Reply #21 on: 21 April 2018, 02:19:28 pm »
We don't have that over here  :rollin
I'll try to find some alternative.
« Reply #22 on: 21 April 2018, 04:26:41 pm »
i have read an aluminium safe descaler has been used to good effect, dishwasher and washing machine descaler is the same stuff
but i really mean it has to be ALUMINIUM SAFE - if you know anyone that works in the kitchen / food prep industry they might be able to get there hands on it
shame the pipes have gone that way
i want to be out riding  in this sun aswell but im rebuilding my entire rear end and just got sent the wrong bolts and still waiting for a new brake disc (that was my fault as i bent it by dropping an engine hoist on it  :wall [size=78%])[/size]
« Reply #23 on: 21 April 2018, 11:32:43 pm »
You can give the engine a good flush using a garden hose. Just take two pipes off and stick the hose in and give it a flush until the water runs clear, then put the hose in the other end to reverse the direction of flow and flush it out the other way. You disconnect the radiator and do it separately. I also took my radiator off and blocked the inlet and outlet and then stuck it in a basin of water and let it soak for an hour to rise dirt out of the fins
Freza
« Reply #24 on: 21 April 2018, 11:47:18 pm »
Great ideas, thanks!
