Date: 11-05-26  Time: 08:58 am
Author Topic: Oil from breather  (Read 3353 times)
reaper1064
Oil from breather
« on: 12 April 2018, 05:15:04 pm »
Well after sitting for a couple of months decided to take the old girl for a clear out run, however on warm up noticed oil coming from the engine breather. Any clues to why this is happening as it was never an issue before,
Re: Oil from breather
« Reply #1 on: 12 April 2018, 07:23:04 pm »
Not the sort of thing I’d expect to notice… mainly because I don’t look in the airbox while the engine’s running. Are you missing the pipe from the breather to airbox?
Otherwise: overfilling with oil or massive blow-by past the pistons will cause excessive oil mist from the breather.
bandit
« Reply #2 on: 12 April 2018, 08:16:10 pm »
This could be normal if the bike has sat for a while most of the oil has drained to the sump/crankcase causing a rise in pressure on initial startup,take it out for a 20 minute run then recheck engine breather. :)
reaper1064
« Reply #3 on: 12 April 2018, 08:36:17 pm »
Cheers Bandit, took it for a blast and it has seemed to settle down, just a bit worrying when you see it.
His Dudeness
« Reply #4 on: 12 April 2018, 09:21:54 pm »
Yea I'd say your breather pipe is blocked with emulsified oil (aka that mayonnaise looking gunk :lol ) and the crankcase pressure is blowing it out the breather. Pop the breather off and give it a clean. The bottom of the airbox will probably need a clean too. You should check your oil level because like the lads said it's probably a bit too high.
reaper1064
« Reply #5 on: 13 April 2018, 09:03:26 am »
Cheers mate
