Date:
09-05-26
Time:
08:33 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
An easy one I expect...forks re-assembling
« previous
next »
Print
Pages: [
Author
Topic: An easy one I expect...forks re-assembling (Read 2976 times)
Geedog
Cager in Training
on:
11 April 2018, 08:09:22 pm »
So I thought I’d be ok doing this but after a week waiting for the seals to arrive it seems i’m Stumped getting them back together..or have forgotten a step..
New seals and dust caps are on and top fork is in bottom fork nice and snug..
The next step - I thought was to put in the damper rod along with its spring and screw in the bottom screw/plug from the end of the bottom fork...on doing this - the top fork is now fixed with no movement which cant be right..
Am i being dumb? What have i done wrong ? (Apart from leave it to a professional..!)
Logged
Naughty Corner
GP Hero
Re: An easy one I expect...forks re-assembling
Reply #1 on:
11 April 2018, 09:52:58 pm »
There's a good write up here
http://foc-u.co.uk/index.php/topic,42.0.html
Logged
Geedog
Cager in Training
Reply #2 on:
11 April 2018, 09:57:46 pm »
Thanks Dudeness, I had seen that one and the only thing I can identify is that maybe fork is stuck, however on unscrewing bottom screw the forks separate with no trouble at all, when the screw is in - no movement..
Logged
Naughty Corner
GP Hero
Reply #3 on:
11 April 2018, 10:10:52 pm »
It's a good while since I did fazer fork seals so you'd be better off waiting for someone else to reply but if I remember correctly if you let the fork fully compress it jams up solid and you have to force it apart.
Logged
Club Racer
Reply #4 on:
12 April 2018, 12:09:34 am »
Geedog, here's the same link as His Dudeness posted but with more pics,
The bronze upper fork bush may not be seated properly see link.
https://www.tapatalk.com/groups/fazerowners/howto-forks-seals-bushes-and-oil-t23188.html
Logged
Jamieg285
Club Racer
Reply #5 on:
12 April 2018, 12:21:56 pm »
It's very easy to jam the upper and lower together. I think I put the damper/lower bolt on before adding the seals. Don't know if that helps or not.
A number of times I had to go back to the vice and hold the lower whilst yanking on the upper to release it.
I also think I only did the bottom bolt up loosely (but enough to seal the oil) until the springs were fitted, then did the final tightening at the end.
Logged
Triggergee
Naughty Corner
Weekend Warrior
Reply #6 on:
12 April 2018, 01:39:03 pm »
I had this problem a few days ago after doing the fork mod.
All you need to do is once the damper rod is screwed in and your getting no movement re-fit the fork into the bottom yoke and tighten it up.
Using a rubber mallet or a small block of wood and a hammer gently tap down on the brake calliper mounting lug or on the side of the fork where the dust seal is and it will free up.
When it's stuck you'll have the white plastic bit jammed into the bottom fork upper/stanchion like in the first picture and you need to tap it out like in the second pic. It jams in very easily so be really careful not to push the stanchion down into the slider as you assemble everything.
Logged
Geedog
Cager in Training
Reply #7 on:
12 April 2018, 08:04:59 pm »
Thanks all, I managed to unstick them, I needed to be a bit more brutal..!
Back on the bike now and looks like no more leaky seals
Logged
redsed
Cager in Training
Reply #8 on:
17 August 2019, 06:23:12 pm »
Thanks for this post, saved my bacon. Just could not figure out the issue until I saw this. Cheers.
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
