Date: 10-05-26  Time: 20:44 pm
Author Topic: Master cylinder seal  (Read 2455 times)
reaper1064
« on: 29 March 2018, 03:14:07 pm »
Hi guys noticed that the cap on my master cylinder has got a weep, looked around but can't seem to locate a seal. Any pointers would be welcome.
BBROWN1664
reaper1064
Re: Master cylinder seal
« Reply #2 on: 29 March 2018, 03:40:22 pm »
Cheers mate  :)
bandit
« Reply #3 on: 29 March 2018, 06:31:53 pm »
Remove the two screws, remove cap do not turn it upside down & place on kitchen paper, place a rag around reservoir & remove rubber seal place on paper then wipe around top edge of res. Check brake fluid level is not overfilled.
Clean rubber seal check condition & clean cap of all fluid,rebuild but don't lean on the screws to much they only need to be snug,wipe around cap then keep an eye on it, you may not need a new seal. :)
reaper1064
« Reply #4 on: 29 March 2018, 09:32:53 pm »
Thanks Bandit will try that first.
His Dudeness
« Reply #5 on: 31 March 2018, 03:58:07 pm »
Yeah it's most likely over filled. Did you put new pads in recently?
reaper1064
« Reply #6 on: 31 March 2018, 04:17:14 pm »
Not touched it scince I bought it, was going to change the fluid when I changed the lines.
His Dudeness
« Reply #7 on: 31 March 2018, 04:23:14 pm »
only asked in case you had pushed the pistons back into the caliper for new pads. if the system is over filled when you push the pistons in the fluid would come out at that cap
reaper1064
« Reply #8 on: 31 March 2018, 04:35:02 pm »
Cheers mate.
bandit
« Reply #9 on: 31 March 2018, 06:31:30 pm »
What the problem sometimes is, is that if the cap has been removed previously & is put down upside down the fluid lays in the cap & the seal & if it's not dried out when the cap is put back on the reservoir it leaks out around between the cap/seal. :)
