Date: 09-05-26  Time: 14:13 pm
Author Topic: Petrol Tank Question  (Read 2805 times)
HarryHornby
« on: 17 February 2018, 10:53:31 am »
When taking the tank off today I went to remove the fuel pipe.  I opened up the clip with some pliers and pulled the pipe and the whole metal tube it came out of the bottom of the tank rather than just rubber tube coming off.
Do I just push this little connector back in or should I glue it?  Has anyone else had this happen?  It's a first for me I must say.
Disorderlypunk
Re: Petrol Tank Question
« Reply #1 on: 17 February 2018, 01:30:28 pm »
the brass insert came out ????
ok thats a new one to me
erm let me get back to you on that
Disorderlypunk
« Reply #2 on: 17 February 2018, 01:57:27 pm »
might get away with smearing it with some liquid metal and sliding it back in place
im not pulling mine apart to check if that will work as it might need a new fueltap
HarryHornby
« Reply #3 on: 17 February 2018, 02:47:47 pm »
It was a new one on me too LOL
Cheers for the replies
I've pushed it back in and it seems tight but I'll go look for some metal glue.  The tap was quite grubby,  I've cleaned it up and will keep an eye on it.  I'm wondering if it's got a slow leak on it so it might be time for another tap.  Looks easy enough to fit, I think even I can do that!   :lol
HarryHornby
« Reply #4 on: 17 February 2018, 05:49:46 pm »
I see you can buy fuel tap repair kit.  Has anyone done this?  Would you recommend giving it a go?
Disorderlypunk
« Reply #5 on: 17 February 2018, 06:07:12 pm »
only if its leaking from the tap or the sealing joint, it doesnt have anything in that will fix the brass pipe problem
if your replacing the tap in the future it cant hurt to have one nearby as they are less than a tenner and saves being off the road for a few more days
daviee
  • Guest
« Reply #6 on: 17 February 2018, 06:23:25 pm »
glue it back in they are more than likely bonded in when made up if it dont leak then jobs a good one
celticdog
HarryHornby
« Reply #8 on: 21 February 2018, 12:17:17 pm »
Cheers Mr Dog, I've ordered some of that!   :)
