Date: 09-05-26  Time: 07:09 am
Author Topic: cut genny cable  (Read 1994 times)
bingo600
cut genny cable
« on: 08 February 2018, 03:00:17 am »
Alright guys, Iv'e had a little mishap and managed to cut the side of my generator cable, ive cut through 2 white wires and cut into blue a little. there looks to be 3 white 1 yellow and 1 blue
Just wondering if these white cables do the same thing, can i just solder them back up?
Trebus
Re: cut genny cable
« Reply #1 on: 08 February 2018, 06:41:43 am »
Usually that would be the 3 windings of the alternator and they are interchangeable. You should therefore be able to solder them up no problem. Normally white wires on a Yam, Honda use yellow as a rule.
Disorderlypunk
Re: cut genny cable
« Reply #2 on: 08 February 2018, 07:54:03 am »
the yellow and blue should be your pick up coil wires so definatly repair the blue one if you exposed any bare wire
bingo600
Re: cut genny cable
« Reply #3 on: 08 February 2018, 06:46:21 pm »
thanks guys il give it bash, i dont suppose it would cause any damage if it doesnt work..
Thanks
