Date: 14-05-26  Time: 04:52 am
Author Topic: Aftermarket gear indicator  (Read 9175 times)
Nemesis
« on: 31 December 2017, 02:14:40 pm »
Anyone fitted a gear indicator? How long did it take and how difficult is it, thanks
Grayo
Re: Aftermarket gear indicator
« Reply #1 on: 31 December 2017, 03:25:25 pm »
I fitted one to a Gen 2 about 3 years ago. I took my time as I had never fitted one before but it was pretty simple and took me about an hour.
I fitted one of these. They are bike specific so just make sure you order the right one. https://www.demon-tweeks.co.uk/motorcycle/gear-indicators/pzracing-geartronic-zero-plug-and-play-gear-indicator
agricola
« Reply #2 on: 31 December 2017, 05:23:15 pm »
I installed one one on my S2 Fazer last year (2016). GIpro X type gear indicator by Healtech. Also has a shift light facility. Bit fiddlt to fit when working in the area around the abs unit, but if your bike doesnt have abs, then it should be straight plug and play. Im dead chuffed with it, worked as soon as installed and set, plug and play. Only slight downside is that if you ever disconnect he battery, the shift light defaults to 6k, and has to be reset back to your preference (mines 12k). I paid £99 and im well pleased with it.
Rob R
« Reply #3 on: 31 December 2017, 09:27:06 pm »
Another with the PZRacing indicator. Took longer to make a bracket than to do the connections.
Rob
Nemesis
« Reply #4 on: 01 January 2018, 02:07:57 pm »
Cheers guys
ptolemyx
« Reply #5 on: 01 January 2018, 03:07:51 pm »
Fitted the PZRacing unit to mine last year. It resets though when working on the bike (ignition on for awhile or battery disconnected) and seems awkward to reset - ride off and up through the gears and typically find sixth indicated with an 8  :rolleyes
moffmeister
  • Global Moderator
« Reply #6 on: 12 January 2018, 08:47:57 am »
+1 for the GIpro X - I fitted at same time as speedohealer (mine is downgeared) - easy to fit and both work a treat
Robgosty
« Reply #7 on: 01 February 2018, 09:17:51 am »
I fitted one similar to this, about £15 of E-Bay, wiring diagram on page 2
https://www.998cc.org/forum/gen-i-mods/22098-gear-indicator.html
blackcabbie
« Reply #8 on: 02 February 2018, 08:00:28 am »
have you got a current link to the 15 pound ebay one, cos i can't find it.....
cheers
steve 10562cc
« Reply #9 on: 02 February 2018, 08:36:55 am »
Excuse my ignorance but what is the point of a gear indicator my ears and rev counter tell me if I need to change up or down.
stet
« Reply #10 on: 02 February 2018, 09:44:18 am »
cheers
Some eBay UK red LED gear indicators are now only £1.50, and some blue gear indicators are only £2.70, both including post and packing.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR3.TRC2.A0.H0.Xmotorcycle+gear+indicator.TRS0&_nkw=motorcycle+gear+indicator&_sacat=0
Dudeofrude
« Reply #11 on: 02 February 2018, 11:52:52 am »
That's the way I've always seen it haha I've never had one on a bike and the ones I've test ride with them have never added much to the ride
blackcabbie
« Reply #12 on: 02 February 2018, 09:41:33 pm »
cheers
those use a magnet on shift lever to work..... i was looking for one that computed gear via speedo and tacho pulses
stet
« Reply #13 on: 02 February 2018, 10:54:24 pm »
Oh, I see.
This is the cheapest computed gear indicator for the FZ1 at the moment (I think):
https://www.ebay.co.uk/itm/Bike-Blue-Gear-Indicator-for-Yamaha-Xjr400-Fzs1000-Xjr1300-Fjr1300-Mt01-Xvs1300A/272827736066?hash=item3f85cce002:g:vtkAAOSwkvdaVzwY#vi-ilComp
https://www.amazon.co.uk/IDEA-Waterproof-Motorcycle-Indicator-Display/dp/B01MZ2C1ZG
More cheap (in case you have never used Aliexpress, they are OK- have bought parts from them):
https://www.aliexpress.com/item/Bike-Gear-Indicator-for-Yamaha-YZF-R1-YZF-R6-Fzh150-Fzn150-Xt660-Fz-16-FZ-S/32831067600.html?ws_ab_test=searchweb0_0,searchweb201602_4_10065_10344_10130_10068_10324_10342_10547_10325_10546_10343_10340_10548_10341_10190_10084_10083_10618_10307_10303_10313_10059_10184_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_40,ppcSwitch_5&algo_expid=9270df4a-bafe-4894-b27d-849cf5a3bd70-0&algo_pvid=9270df4a-bafe-4894-b27d-849cf5a3bd70&priceBeautifyAB=0
https://www.aliexpress.com/item/Motorcycle-Gear-Indicator-for-Yamaha-YZF-R1-YZF-R6-Fzh150-Fzn150-Xt660-Fz-16-FZ-S/32809037434.html?ws_ab_test=searchweb0_0,searchweb201602_4_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10192_10190_10084_10083_10618_10307_10301_10303_5722316_10313_10059_10184_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_40,ppcSwitch_5&algo_expid=b74951dd-32d2-444b-8e04-e425d10cbc86-1&algo_pvid=b74951dd-32d2-444b-8e04-e425d10cbc86&priceBeautifyAB=0
blackcabbie
« Reply #14 on: 03 February 2018, 08:24:52 pm »
thanks for info     :)
Nemesis
« Reply #15 on: 23 April 2018, 04:34:55 am »
Has anyone got a pic handy of where the ECU plug is please much appreciated  :D
tommyardin
« Reply #16 on: 23 April 2018, 07:35:56 am »
