Date: 21-03-26  Time: 17:27 pm
Author Topic: Overheated?  (Read 2173 times)
gnm
Overheated?
« on: 24 December 2017, 08:36:10 pm »
Hi all, started the Fazer up last night after about 8 weeks in the shed and left it running for about 20 minutes then it cuts out. When I went to check it there was steam and water coming out from around the rubber overflow pipes behind the exhaust link pipe. I left it to cool down then tried to resart it but only getting a loud clicking from around the positive side of the battery any ideas?
Gaz66
Re: Overheated?
« Reply #1 on: 24 December 2017, 10:03:24 pm »
Probly Thermostat that's failed in it's closed position causing bike to overheat from what u describe?
Drop bike onto it's wheels, push it in top gear & check engine will still turn over ?
If not motors likely seized as starter motor won't crank it over..
Or you could just have a starter/solenoid/battery/charging issue?
Hopefully it's summat simple to fix.
gnm
Re: Overheated?
« Reply #2 on: 24 December 2017, 11:01:36 pm »
Ok cheers will try that tomorrow. Was turning over very slow like flat battery but battery was ok beforehand
gnm
Re: Overheated?
« Reply #3 on: 03 January 2018, 11:48:25 pm »
Sure enough thermostat stuck, battery flat. New optimiser arrived sat charged it up, topped up coolant and all seems ok now
Gaz66
Re: Overheated?
« Reply #4 on: 07 January 2018, 06:56:43 pm »
Nice one.
Glad to help mate :thumbup
