Date: 13-01-26  Time: 05:02 am
Author Topic: Replacing Rear brake disc  (Read 13386 times)
Re: Replacing Rear brake disc
« Reply #25 on: 25 November 2017, 10:08:44 pm »
The allen bolt head rounded off, so after a lot of swearing i cut a slot into it but it still wouldn't budge, even using an impact driver.
Mate saved the day again as he had a blow torch and the heat freed it enough to undo it.
Ran out of light so i'll put the new disc on tomorrow now.
Had an issue with my new PR4 tyre as well.
We reckon it may have been at the bottom of a pile of tyres which made it a bit narrow, so even with a ratchet strap my mechanic couldn't get any air into it.
Fortunately he happened to have another tyre there and he put that on for me instead, which was lucky.
In etween dropping it off and picking it back up i spent a couple of hours servicing and regreasing all of the brake calipers so i've had a productive day, albeit a lot longer than intended plus it was bloody freezing outside.
I've decided i'm not going to use threadlock this time, i'm gonna dip the bolts in engine oil then torque them up.
I might check them every few months anyway but i don't reckon they'll budge at all.
Sensible man.
But replace engine oil with copper slip or Red Rubber grease. I check all my bolts every few months, I don't crack them up tighter I just apply some pressure to them and it tells me if they are loose or not.
The only part of my bike I apply LocTite to is the front drive chain (Gearbox) sprocket, then I use to one that go rock hard LocTite 620.
« Reply #26 on: 25 November 2017, 10:32:55 pm »
LOL! As said in another post a few days ago opinions are like arse holes everyone has one.
Best do your own thing that you are happy with, cos one person will say one thing and another something completely opposite.
Just keep a check on the bolts, if one did come loose it is unlikely to come out and lock the rear wheel, they are spinning at an incredible rate of revolutions and the fists bolt that touches the caliper will make such a din you will pull over to see what it is.
(Be like the old clothes peg and piece of plastic you had on your pushbike you had flicking against you spokes as a kid)
My guess would be that the bolt would only come undone a few turns before it touched the caliper and I'm sure all 5 or is it 6  will not all come loose at the same time.
Anyway good luck with whatever you decide to do Darrsi, your the man who makes the final decision, don't take any notice of anything I say as I am a suicide pilot. :eek
« Reply #27 on: 26 November 2017, 12:12:21 am »
I shredded my rear caliper pad pin using copper grease with a torque wrench, even though it was set at something daft like 10Nm.
Copper grease really fooks up torque readings, i've posted on here before about it, but the findings were that if engine oil is used instead then torque settings remain accurate.
I don't know anyone who's ever had a disc bolt come loose if they have been torqued correctly, i just can't see it happening, and as my bike's a commuter plus the fact i'm more pedantic than most at checking things then i'm very confident i would never have an issue.
Add to that i'm lucky if i can hit 40mph going to and from work then i reckon i really won't have any grief.
If i was racing or generally ride like a maniac then i would reassess, but FOR ME that's simply not a problem.
I'll dab a spot of Loctite on and be done with it, but from experience those bolts are a bastard to undo with brute force, so thinking that one may work itself loose just doesn't seem like reality to me.
I admit prevention is better than cure but in this case i just don't see a problem.
If shit happens i'll be the first to shout about it, but there is that chance i will be the first on here!
« Reply #28 on: 26 November 2017, 12:42:35 am »
I s'pose you really have to take in to consideration that when things go wrong the owner has to take responsibilty too.
We hear of things going bad, but if everything's torqued correctly for example then things should be fine.
I bet there's a lot of people on here that don't even own a torque wrench?
« Reply #29 on: 26 November 2017, 04:11:40 pm »
Just took the bike out to try and scrub the tyre in a little bit while the roads are dry as it was so shiny and slippery i dread the thought of what it would be like in the wet.
It was worth all the effort though, a new tyre always feels great anyway and spending a few hours cleaning up and regreasing the calipers a couple of times a year works wonders in the long run.
Job's a good'un  :)
« Reply #30 on: 26 November 2017, 05:24:52 pm »
Sounds like you have it nailed :D
Jamieg285
« Reply #31 on: 27 November 2017, 01:56:14 pm »
If it makes you feel any better, I tried to do my front discs yesterday.  11 bolts fine.  1 bolt rounded out. Smacked in a slightly bigger imperial allen head socket and had a go with that, and it sheared the bolt - below the level of the wheel hub  :'(
Attacked it with a drill, got the centre out and tried some bolt extracters.  Got them to bite on the bolt, but it's stuck fast  :'(
Drilled out out as far as I could without going into the threads, but still no joy.   I've been out and bought a 6.8mm drill bit and an M8 tap to try as a last resort.
The PR4s are a toughy to fit.  I've had 2 and neither wanted to seal the 'normal' way.  The trick I used (borrowed from a fitter) is to fire a burst of un-restricted compressed air down the bead rather than through the valve.   There's a proper tool to do it (Bead Cheater?), but that's expensive, so I just hooked up a piece of hose pipe to the compressor outlet and it worked just as well.
« Reply #32 on: 27 November 2017, 04:36:57 pm »
The bolt heads are so soft it's a joke, but I learned from before to make sure I have spares before even attempting to remove any.
Jamieg285
« Reply #33 on: 27 November 2017, 04:47:16 pm »
I bought the spares ahead of the job, but that's not the problem - It's being able to put it them in again.
Browsing ebay for spare wheels locally now...
« Reply #34 on: 27 November 2017, 05:13:53 pm »
I know it's not something most people have, like me for example, but putting a blowtorch on mine really worked wonders in a couple of minutes to soften the Loctite. If you have an extractor and you've already got it to bite then it may be worth giving it a go.
Hugh Mungus
« Reply #35 on: 27 November 2017, 09:21:22 pm »
A blow torch is a pretty cheap thing to buy. It's worth getting one to make the job a whole lot easier.
I wouldn't attempt to undo disc bolts without heating them up first.
« Reply #36 on: 27 November 2017, 09:42:47 pm »
if i ever buy another blow torch i will buy the one with the piezo igniter cause sods law the moment you need it you wont find a lighter
-and when you turn to the backup matchsticks that have sat in the drawer for 3 years you realise they got damp and wont light
Hugh Mungus
« Reply #37 on: 28 November 2017, 05:51:53 am »
Yep, and now I have stopped smoking the ciggies I don't carry a lighter around all the time. You can bet the one in the garage will go missing when someone borrows it to light their fags.
Jules-C
« Reply #38 on: 28 November 2017, 12:29:57 pm »
Also check eBay for left hand drill bits the heat from drilling softens the threadlock and the left-handed turn can start to undo the bolt at the same time
Jamieg285
« Reply #39 on: 28 November 2017, 02:08:17 pm »
Too late now.  The 6.8mm got the remains of the bolt out and I cleaned up the threads with a tap.  All looked good until I tried to torque them and the thread gave way.
I'll have a look at threaded inserts next, but I'll have to get another wheel, as I need to be back on the road next week.
« Reply #40 on: 28 November 2017, 03:24:03 pm »
Damn, what a nuisance!  :'(
« Reply #41 on: 28 November 2017, 05:32:02 pm »
wurth time serts job done they are about the best about only take a couple of hours to do them all
« Reply #42 on: 28 November 2017, 05:59:27 pm »
 :agree :thumbup
« Reply #43 on: 29 November 2017, 02:58:51 pm »
just wondering if anyone has had success using a manual impact driver on these
i.e the one you hit with a hammer not the 'Buzz gun'
as it is a hammer thump and a turn in one where a buzz gun is more just rotational whacks?
just a thought
« Reply #44 on: 29 November 2017, 03:49:34 pm »
just a thought
That's what I was initially using for my rear disc on Saturday. Would've worked a lot easier after a bit of heat, even though 5 out of 6 worked straight off.
Was worried a little bit though because it was so cold outside I was scared of cracking the wheel hub.
« Reply #45 on: 29 November 2017, 03:59:47 pm »
its another one of those tools i have been meaning to buy for ages but when i need one i find another way (cant wait for delivery)
and then i forget about buying one untill i next need one and the cycle repeats itself
getting 5 out of six easily out definatly says its worth having one for that job though considering the problems others are having
« Reply #46 on: 29 November 2017, 04:19:05 pm »
I've only put a small dot of Loctite around 4 threads from the top of the head this time which should spread when tightening to cover them all, but if I heat them next time and use the impact driver I won't accept anything but instant success on all 6 bolts.  :lol
Trebus
« Reply #47 on: 29 November 2017, 10:39:33 pm »
Impact drivers can definitely get you out of here shit. The trick in my experience is to use it first, once any button head Allen bolt starts to get rounded they are always a bit of a game. Sometime you can knock a Torx bit in instead if it rounds.
Never done the Fazer disc bolts but had a game on other bikes over the years. Luckily no defeats though 😀
« Reply #48 on: 30 November 2017, 06:18:12 am »
I just don't see why they have to use allen head bolts made from marshmallows though.
Why not use hex bolt heads instead, then when removal time comes just use a 6 sided socket, which impact sockets are anyway, and it should make life much less stressful.
celticbiker
« Reply #49 on: 30 November 2017, 07:21:13 am »
As an engineer I would agree, practical functional and future proof but button heads are considered more aesthetically pleasing.
If practicality was a consideration everything would be Stainless and bike would be a lot more expensive.
It goes together quick, looks pretty and the components are cheap. One it's our of warranty it's your problem.
