Date: 01-02-26  Time: 09:27 am
Author Topic: Bike doesn't turn on / no lights  (Read 6249 times)
Diogo.fps
« on: 18 November 2017, 02:29:43 am »
Hey everyone.
My 2003 Fazer 600 stopped working for no apparent reason.
Rode it to work, everything was fine. When i was about to go back home, she didn't turn on.
When i turn the key, no lights come on, at all.
I've tried another battery and it still doesn't work. Also, I've checked the fuses and they are intact.
Has this ever happened to anyone?
I have no idea of where to look.
Re: Bike doesn't turn on / no lights
« Reply #1 on: 18 November 2017, 07:57:46 am »
either a dead battery of main fuse or corroded ignition barrel plug get the multi meter out also check the main fuse at the starter relay
« Reply #2 on: 18 November 2017, 09:05:31 am »
Check the connector bundle in the plastic box under the tank for one that’s showing signs of getting hot.
Examine the wires at the base of the ignition switch itself, they have to flex with steering movement so it’s a common place to get a breakage.
« Reply #3 on: 18 November 2017, 09:05:47 am »
Worth a check. The cable from the battery that goes down to earth/ ground on the engine casing, right hand side of the bike at the back of the engine, at this point they can get a form of white powdery corrosion where the steel bolt and the alloy engine cases join (some sort of electrolysis) take the bolt out wire brush the bolt and WD the the bolt hole in the engine case. Make sure the circular cable connector is clean as well. Only take 10 mins tops and if it makes no difference you have at the very least eliminated poor grounding.
If it is corroded badly and no connection it has the same outcome as not having that earth or ground lead attached to the battery. Good luck.
« Reply #4 on: 18 November 2017, 09:25:08 am »
Years ago I had a prick pen, now, now that's enough lads, allow me to continue.
It was like a ballpoint pen with a very sharp short needle at one end and a small bulb at the other end, half way along its length it had a flying lead about 2 foot long with a small crocodile clip.
Now somehow the needle and the centre contact on the bulb must of been connected and the flying lead to the mount or negative side of the bulb.
It was brilliant for finding out if cables had power and you could work your way along the length of a cable or wire and find the exact point the the break was. The needle made such a fine hole in the insulation just rubbing that sport hard with a thumb nail and it seemed to disappear.
 I,m going to make one, it's not rocket science. Sewing machine needle,  six inch length plastic tube, small bulb (12 volt) and bulb holder, wire a crock clip and builder bucket full of aradite. Jobs-a-Goodun
Update:
thinking about it you could do exactly the same thing using a multi meter with a very sharp positive probe
« Reply #5 on: 18 November 2017, 12:09:50 pm »
Update:
just get some spare leads for your multimeter and solder a sewing machine needle to it on positive side (just key the multimeter surface first to make sure it gets a good hold)
- could try tacking it on with a welder but i have a feeling something would melt first
« Reply #6 on: 18 November 2017, 01:53:55 pm »
I get the feeling that the Multi-meter probe would act more like the welding rod than the welding rod did on my 180 amp ark welder, it too fierce for a car body and exhaust repairs, :eek  blows hole rather than mends.
« Reply #7 on: 18 November 2017, 04:30:17 pm »
Home made Prick Pen circuit tester:
2.  Single Chocolate Block Connectors.
1.  Crocodile Clip.
1.  Jewellers Screwdriver Bit.
1.  Length of Wire (Preferably Black 2'6" Long)
Tools Needed:
Fine file to sharpen the Jewellers Screwdriver bit to a point.
Soldering Iron to solder the Crocodile Clip to on end of the length wire and to tin the other end.
Can be used to check if a wire
has current, can be used to find the point where the break is by checking along a wire length.
Can still be used as a normal Multi-Meter to check continuity and resistance. Undo the two screws that grip the probes and your back to a standard Multi-Meter   The Screwdriver bit I used was from a Rolson Jewellers mini screwdriver purchased from Robert Dyers, it comes with about 8 or 9 bits held within the body of driver
The rest as they say is!         See pictures.
Diogo.fps
« Reply #8 on: 18 November 2017, 09:47:25 pm »
Hey guys, I've found what the problem was! :)
Under the tank there's a box with a lot of cables and connections.
Apparently some water found its way there, and this happened:
IMG 20171118 WA0001
IMG 20171118 WA0001
That's the connector/cable coming from the ignition, t
hat's why when I turned the ignition on, no light would come on.The cable itself is really stiff and stripped, so I should replace all of it.
Either that or replace the ignition + seat lock + petrol cap, if I don't feel like messing with wires.
Maybe this wouldn't have happened if the bike had the a 10A ignition fuse (as it should) instead of the 25A one it had.
I've found out about the fuse yesterday and i've already replaced it.
« Reply #9 on: 18 November 2017, 10:31:54 pm »
Hi Diogo,
Me thinks you got away very lightly with that, there was potential there for a mas of destruction, possible fire in that box that could have set fire to the plastic that the box is made of melting the main fuel line from the tank to the carbs 'BOOM' Good night Fazer.
Diogo.fps
« Reply #10 on: 18 November 2017, 11:26:32 pm »
Hi Diogo,
And possibly "Good night Diogo" too lol
Yeah I thought about that too, from now on I'll be checking a lot more when I buy a used bike.
It's my fourth, but I've never seen anything like this (nor this dangerous) before
« Reply #11 on: 18 November 2017, 11:55:55 pm »
Takes some serious water to get there, have you ever jet washed your bike recently?
« Reply #12 on: 18 November 2017, 11:56:21 pm »
You were unfortunate and yet fortunate at the same time. Glad it all worked out. But not quite sure why you are replacing the ignition, fuel tank and seat locks, if it was just water getting into the box (plus I would guess a loose connection on the joint) causing it to ark and spark, just make a repair to that section of wiring useing a largish chocolate block connector or maybe two if you are going to replace a short length of the burnt part of cable, keeping the chocolate block connectors within the confines of the black box, give the whole of the inside of the box a goood blast of WD 40 and you should be good. Replacing all those switches will be very expensive and time consuming.
The FZS 600 is a wonderful machine, very reliable, goes very well (quick) an is eager to please most Fazer owners whether the 600 or the Mighty Thou have a permanent grin when riding.
Great choice of bike.
« Reply #13 on: 19 November 2017, 12:07:32 am »
Not convinced myself that it's just water damage as plugs are melted,why is there a 25 amp fuse where a 10 amp should be.  Shocked
celticbiker
« Reply #14 on: 19 November 2017, 09:50:48 am »
Doesn't look like water damage to me either. Looks more like a short circuit or high current load causing the connector to overheat.
I guess if the connector spades are badly corroded it could cause a high resistance and result in what you see.
It's possible that the previous owner had fuses blowing because of this so just chucked in a big fuse to get around it.
After repairing this problem I would suggest checking all the other connectors and cleaning with Duck oil (not wd40) or acf 50 to prevent any future problems.
« Reply #15 on: 19 November 2017, 11:38:45 am »
According to the wiring diagram for the 02 model, the ignition fuse is 20A.
It doesn’t look to me as if water was involved: that plug carries power for almost everything, including the headlights, so the currents are quite high. If the connection is not making very tight contact this will result in overheating.
Diogo.fps
« Reply #16 on: 19 November 2017, 01:22:19 pm »
No  darrsi, i've never jet washed it, don't know about previous owners though.
I thought about changing the ignition just in case I didn't manage to fix the wires, it's more of a backup plan. And if i change the ignition, i would have to change the fuel tank lock and the seat lock too, too keep using just one key. (i found the 3 of them for about 50€ on ebay). But yeah, that's just a backup plan if all else fails.
I'd like to literally replace that wire with another instead of fixing just the tip of it. That's because I can't be sure the rest of the wire isn't as bad as the tip of it, all i know is that it's stiff, and i guess it shouldn't be.
And thank you, it's the 2nd Fazer i have :) It's such a versatile bike
But since the wire is stripped at the tip, if water got there, wouldn't it short-circuit?
So, by cleaning all connectors I would lower their resistance and prevend them from overheating, is that it?
You're right, I was thinking of the signal fuse, not the ignition one. So I guess you've debunked my theory ahah, nothing to do with fuses
Here's how the fuse box was (25A fuse on 10A signal)
« Reply #17 on: 19 November 2017, 02:06:16 pm »
I think the mostly likely cause was the connection became loose, which caused increased resistance, which caused increased heat, which melted the connector and started to melt the wire. That continued to happen and got worse over time until the point where there was too much resistance and not enough current could get through to turn on the bike. That would be my guess on what happened. The best fix would be to cut back the wire on both sides of the bad connector until you get to clean undamaged wire and then solder and heat shrink in a new wire and crimp on a new oem style connector.
« Reply #18 on: 19 November 2017, 02:14:13 pm »
I don't think a poor connection like you had there will blow a fuse. I think a poor connection will cause increased resistance which causes a voltage drop so less current flow so the fuse won't blow. A short circuit on the other hand which is where a power wire comes in contact with a ground before it goes through the load will cause increased current flow because a short is basically removing the resistance of the load so it's the opposite of a poor connection. So way more current flows which blows the fuse. That'd explain why your fuse didn't blow.
celticbiker
« Reply #19 on: 19 November 2017, 02:55:51 pm »
It's surprisingly difficult to short circuit something with water unless you submerge it or pour on a cup full, corrosion over time causing resistance is usually the result of water ingress
Yes, cleaning connectors and preventing future corrosion via Duck oil or ACF50 will lower the resistance (to within designed parameters) and prevent this from happening in the future.
I do this globally every 2 years and every year just before winter on exposed or important ones like the main relay and the two connector blocks on top of the radiator (Fazer 8).
I cover 20000 miles/year in all weather and cannot stress enough the need to properly maintain the electrical system and having a few spares makes an unexpected breakdown a lot less stressful.
I always keep a main relay, starter relay and flasher relay on hand just in case but that's just me as I also keep a full set of chassis bearings ( wheels, swing arm and headstock) chain and sprockets and a set of fork seals and spare wheels with tyres, just makes life so much less stressful.
« Reply #20 on: 19 November 2017, 07:56:42 pm »
Hi bandit,
I guess it could just be that the connection was corroded slightly either by a water ingress or corroded because of a loose connection arcing and sparking. A loose joint like that causes burning and blackening of a contact, that in turn causes more arcing and the fuse to blow and the previous owner got over the blowing fuse by shoving a heavy fuse in line, that in itself would seem to cure the problem until the joint became so unstable that it melted the connector.
My guess would be it had nothing to do with a water ingress but a loose arcing connection. IMO  :rolleyes
« Reply #21 on: 19 November 2017, 11:39:17 pm »
holy crap what happened there - not been on this post in a while expecting it to be a simple thing like a loose connector that just needed you to find
but bloody hell thats an impressive failure
does look like it could have been corrosion on the connections causing a smaller contact patch causing excessive heat and in turn smouldering connector block
but who knows - a bit of trimming and the correct type of connector and you will be laughing again
i will repeat this bit - CORRECT TYPE OF CONNECTOR BLOCK
i do that because there are certain types of block i see that never belong in a bikes wiring loom
Diogo.fps
« Reply #22 on: 21 November 2017, 01:09:53 am »
Thank you to everyone who's taking the time to explain, as you can see i'm no expert   :b
But I'm learning bit by bit
I was intending to try to find the same type of connector block that the fazer originally uses.
But can you tell me what's the problem with that connector anyway?
« Reply #23 on: 21 November 2017, 01:27:20 am »
it is just a bodge pure and simple and i love a bodge here and there to work as a fix untill it can be done properly (i use a lot of them)
but that connector block was designed for use in houses and is an unsightly thing on a bike
a OEM connector is often not available and cost a fortune from aftermarket suppliers and i rarely use them
but a crimped bullet/spade connector is the way to go as they are made for vehicles and not your house
[edit] assuming you are meaning the block i pictured - there is nothing wrong with the oem block its unfortunate that yours had a failure that is rare to see
celticbiker
« Reply #24 on: 21 November 2017, 06:47:50 am »
A simple 2 pin waterproof connector can be had here.
https://www.ebay.co.uk/itm/1-11-WAY-PIN-6-3mm-ELECTRICAL-MULTI-PLUG-CONNECTOR-TERMINAL-BLOCK/151430793986?hash=item2341fa8b02:m:mKBHjPHLBRnoNP_YZtXs2dg
But you can also get waterproof ones here
http://www.ebay.co.uk/itm/2-Way-Pin-Car-Auto-Waterproof-Wiring-Cable-Electrical-Multi-Connectors-Block/271683539695?hash=item3f4199d2ef:g:0skAAOSw2XFUbGkZ
But do ensure the correct load rating before buying.
