Date: 07-05-26  Time: 22:43 pm
Author Topic: Very strange rich idle  (Read 1887 times)
mars696
« on: 18 October 2017, 07:39:07 pm »
Hi again guys!
Soooo after solving this freaking problem...http://foc-u.co.uk/index.php/topic,23230.msg267705.html#msg267705
i am facing another fuel problem that was coexisting with the previous one.
As i am standing at a traffic light or a crossroad or something like that,with the engine fully warmed, and i lightly blip the throttle the rpms drops significantly and come again at proper idle speed or when i try to start moving the bike feels too rich and want more throttle opening.
The pilot screws are adjusted at approximately 2.5 turns (01 model), if i try to reduce this,the bike doesnt idle properly.
I have tried to set the float heights in many different settings.
To archive the 3.5 mm above mating surface like Yamaha suggest, i have to set the float height at approximately 15+ mm above carb surface when bench setting them,but the bike with that setting, fills very strange and wont idle properly again.
Now i am at ~13.5 mm and with the tube test it reads something like ~6.5mm above mating surface.
I m confused again for focs sake! :rolleyes
Air filter is clean,carbs are very clean, i have this problem with both carbs sets i have( spare parts!!!!), pilot jets are yamaha's 12.5.
Any help or idea will be much appreciated, because i am out again... :'(
daviee
  • Guest
Re: Very strange rich idle
« Reply #1 on: 19 October 2017, 06:36:19 pm »
if its the same with both sets of carbs then it unlikely its a carb issue sure you dont have an air leak or duff plugs or caps or even tps
mars696
« Reply #2 on: 19 October 2017, 07:26:24 pm »
I am sure i dont have air leaks 100%! plug caps are ngk one's and tested with the oem too,tps its ok, i have 3 of them :'( :lol  and all work the same.
The spark plugs are ngk iridium and they seem fine to my naked eyes.
Thanks for the responce mate!
I forgot to mention that the bike has k&n air filter and an akrapovic exhaust.
I also check today the pilot screws are set at 2.5 turns for cylinders #1,2,4 and 2 3/4 for cylinder #4
daviee
  • Guest
« Reply #3 on: 19 October 2017, 07:30:46 pm »
dont no what mine are set at but i run a k and n and scorpion can and it runs perfect no hesitation anywhere and goes like stink it will put in top gear from 2 k till it passes 140 with no issues at all  so i dont think your set up is wrong but if you have a air screw different from the rest that could be an issue
daviee
  • Guest
« Reply #4 on: 19 October 2017, 07:35:42 pm »
in the book 98/01 pilot screw settings should be 2  turns out
mars696
« Reply #5 on: 20 October 2017, 04:04:47 pm »
Today i manage to pull out the carbs again and i change the orings at the float needle nests(is this term right?)!
The problem seems to be solved! :)
daviee
  • Guest
« Reply #6 on: 21 October 2017, 05:22:08 pm »
nice one that would cause flooding
