Date: 07-03-26  Time: 20:43 pm
Author Topic: Datatool system3 removal  (Read 1363 times)
Woodzey80
« on: 03 September 2017, 01:21:05 pm »
Anyone removed one from a gen1 thou ? If so was it difficult ?
FILZ6
Re: Datatool system3 removal
« Reply #1 on: 03 September 2017, 07:33:24 pm »
Not difficult as such, but time consuming.
Take your time, address one wire at a time. All the wires on the alarm are black, no id, so if you don't label them yourself before you start it is non reversible.
Alarm wiring is spliced/soldered into the bikes wiring, remove them then re-solder the colour matched original wiring back together. One at a time.
Must confess I was worried when I tackled mine, but had no problems. Off memory took me an afternoon, but I did tend to fanny on checking then double checking, worked out well in the end. Good riddance to datatool.
Dis-connect the battery before you start.
Good luck.  :)
Woodzey80
« Reply #2 on: 03 September 2017, 07:54:49 pm »
Thanks a lot for the reply, I will take the job on myself then when I get some spare time. Cheers
Woodzey80
« Reply #3 on: 16 September 2017, 03:27:44 pm »
SORTED !!
Sorry the site won't let me upload a pic
