Date: 26-03-26  Time: 01:06 am
Author Topic: tool for fork rebuild  (Read 3033 times)
celticdog
« on: 23 August 2017, 12:40:34 pm »
Unfortunately I've got a leaking seal so it's time to do some maintenance the bank holiday weekend. To loosen the bottom bolt (M8)on the bottom of fork leg, requires holding the inside damper rod- the usual method is to use a broom handle.
Manual refers to Yam tools (90890) but no idea of what it looks like. From memory I think it's a hex. If I knew the size and shape I could weld something onto a long rod and reach down there.
Has anyone made similar or have any ideas with size and shape help?
BBROWN1664
Re: tool for fork rebuild
« Reply #1 on: 23 August 2017, 01:47:44 pm »
I used a broom handle.
Bretty
« Reply #2 on: 23 August 2017, 02:21:46 pm »
^^that's what I did. I had a 1m length of wood  about 30mmx20mm. I whittled the last 4inches into a tapered point. Just give it a whack and it wedged in and I could prevent it from turning whiled I shocked the bolt out.
I made a seal seating tool using one bit of split plastic tube inside another with a jubilee clip on the outside
celticbiker
« Reply #3 on: 23 August 2017, 02:27:10 pm »
I think I might have some lying around that I made for the tdm, might be the right size.
Can post one or if you want to try it.
celticdog
« Reply #4 on: 23 August 2017, 03:23:52 pm »
Nice one can you stick up a pic fella, then I can see what it looks like.
bandit
« Reply #6 on: 23 August 2017, 05:07:18 pm »
celticdog,this may help ya.Smile
Bretty
« Reply #8 on: 24 August 2017, 06:28:38 am »
There's a photo of a fella holding said tool on this, as well as it being good clear instructions for the job:
http://fazerowners.yuku.com/topic/23188/HOWTO-Forks-Seals-Bushes-and-Oil
celticdog
« Reply #9 on: 24 August 2017, 10:35:20 am »
I’ve found some dimensions online! It’s basically a square taper shape. I’ll get me pen knife out.
« Reply #10 on: 24 August 2017, 11:05:39 am »
this is what i made . bit of softwood whittled down . as your drawing 20ish mm...
daviee
  • Guest
« Reply #11 on: 24 August 2017, 09:15:34 pm »
old 1/2 inch extension ans grind it to the shape
