Date:
19-04-26
Time:
18:49 pm
Home
Media
old - Fazer Owners Club - old
Removed / replaced front wheel, now speedo etc not working - help???
« previous
next »
Print
Pages: [
Author
Topic: Removed / replaced front wheel, now speedo etc not working - help??? (Read 2298 times)
Jrebera
Cager in Training
on:
22 August 2017, 06:25:26 am »
Hey peeps, I changed tyre on front wheel myself (Whoop!), but now my speedo isn't working. I tried to line the drive gear up - but no success. I did notice the cable has a kink - could that be the problem? Any suggestions? Thanks peeps
Logged
GP Hero
Re: Removed / replaced front wheel, now speedo etc not working - help???
Reply #1 on:
22 August 2017, 06:39:41 am »
Not sure why you would have a kink in the cable, but check it's not rubbing on anything anyway.
Most common mistake is not lining up the lugs properly on the speedo sensor rotor, then when you tighten up the wheel nut the lugs just crush and snap off.
Highly likely to be this, but the only way to find out is to take the wheel off again and have a look.
Number 15
https://www.ajsutton.co.uk/genuineparts/9796/41/yamaha-fzs600-fazer-2002/meter?uID=0
Logged
adeejaysdelight
WSB Pack Hound
Reply #2 on:
24 August 2017, 10:31:39 am »
Darrsi is dead right here. It's a bit footery getting the wheel back on right on your own. A third hand/arm would be useful. Take it back off and make sure everything is seated properly. If the lug's are damaged, you can get a replacement easily enough.
Logged
maddog04
Naughty Corner
GP Hero
Reply #3 on:
29 August 2017, 05:45:38 pm »
with Darrsi, happened to me years ago when I had the 600, easy replacement which is good
Logged
GP Hero
Reply #4 on:
29 August 2017, 08:09:11 pm »
You tend not to do it twice.
Logged
crickleymal
Naughty Corner
Club Racer
Reply #5 on:
30 August 2017, 12:53:11 pm »
Did that on a Divvy. I bought a new ring with lugs off ebay or somewhere but in the mean time silver soldered the old one back together. As far as I know it's still working three or four years later.
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
