Date: 19-05-26  Time: 15:08 pm
Author Topic: Alarm wiring question  (Read 2461 times)
solorider
« on: 18 August 2017, 10:42:40 am »
in the process of doing my bike up I have changed the wiring harness, on the "new" harness there is 2 plugs with one of them having a joining wire, I presume this is for the alarm, so anyone know which wire does what and can you buy the plugs? My old harness didn't have these plugs.
Gaz66
Re: Alarm wiring question
« Reply #1 on: 21 August 2017, 07:41:03 pm »
Hi ya.
Is it the 2 white 2 pin plugs just rear of the battery box you refer to?
Does the bike run?
If not both 2 pin plugs need a jumper wire in each plug, i believe 1 plug is fuel cut off & 1 plug is ignition cut off.
Bike should then run ok.
I had to jump both mine when when i Unpicked a Meta alarm that went tits up.
Hope this helps matey..
solorider
« Reply #2 on: 22 August 2017, 07:06:33 pm »
One of the plugs does have a jumper in it but I think the other is missing, I do have an alarm to fit and would rather use those plugs rather than splicing into the harness, but I need to find out which wire does what.
Dustydes
« Reply #3 on: 23 August 2017, 01:40:02 pm »
Have a look sat my post 8 down. Interlock started by Dustydes
I cant help you more than that as no idea myself but someone with electrical knowledge could test/trace wires.
Read all reply's in post.
Des
