Date: 20-04-26  Time: 13:51 pm
Author Topic: Speedo not working  (Read 2988 times)
reggit
Speedo not working
« on: 04 August 2017, 09:59:50 am »
Hi all,
Next question - my speedo isn't working.  Can someone point me in the direction of the pickup please?
BBROWN1664
Re: Speedo not working
« Reply #1 on: 04 August 2017, 10:34:34 am »
gearbox
reggit
« Reply #2 on: 04 August 2017, 10:46:17 am »
gearbox
Do you mean on front sprocket?
reggit
« Reply #3 on: 04 August 2017, 12:49:20 pm »
Found a decent thread on the subject, so please ignore this one.
http://foc-u.co.uk/index.php?topic=476.0
Gaz66
« Reply #4 on: 04 August 2017, 07:46:56 pm »
 Check the multi-plugs under left headlamp fairing infill panel, all live feeds to clocks & lights go thru these plugs.
Any corrosion or bad connection at all in these plugs will cause a whole load of electrical gremlins, from no lights at all, to flickering clocks, to no speedo etc.
It's a very time consuming job pulling every wire from the plug to clean em up, I stripped/cleaned every plug on my full loom, everything now works mint.
reggit
« Reply #5 on: 04 August 2017, 08:20:18 pm »
Ignore this!
reggit
« Reply #6 on: 07 August 2017, 07:51:46 am »
and this! - wrong information
reggit
Re: Speedo not working - stuck!
« Reply #7 on: 09 August 2017, 08:43:25 pm »
More info - and I'm stuck!
Have continuity from instrument cluster white wire to speed sensor plug white.
4.8v on white at speed sensor plug - sensor disconnected
0v at plug with sensor connected
with instrument console plug disconnected the voltage at the sensor is 4.8v with the sensor connected or not - not switching when bike moved (no centre stand)
I've bought a new (used) sensor, but it's doing the same, which sort of rules the sensor out.
The multiplugs under the infill panel are not corroded.
reggit
« Reply #8 on: 19 August 2017, 09:46:11 am »
I'll just put the solution in my case on here in case someone reads it in the future.
I found a fault in the instrument cluster - it smelt of burning circuitry when I opened it.  Suspect this killed the 2nd sensor, as it initially tested ok.
Bought a cheap used set of clocks and another sensor and it now works.
