Date:
29-03-26
Time:
00:24 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
Loose exhaust
« previous
next »
Print
Pages: [
Author
Topic: Loose exhaust (Read 2158 times)
Oxygen
Weekend Warrior
Loose exhaust
on:
22 March 2012, 10:30:21 pm »
The round bracket that goes around my stock exhaust is a bit loose. It maybe the spot welds have come loose in parts. I have notice some after market exhausts have a "rubber" strip underneath the round bracket.
Can these be purchased separately and if not could you recommend something else that would work and be able to deal with the heat ?
I can only find this but it seems like I would have to break my clamp off
http://www.ebay.co.uk/itm/MOTORCYCLE-EXHAUST-STAINLESS-STEEL-CAN-STRAP-105mm-120mm-RUBBER-INSERT-/300618378227?pt=UK_Motorcycle_Parts&hash=item45fe406bf3#ht_734wt_689
Logged
chunk166
Naughty Corner
Weekend Warrior
Re: Loose exhaust
Reply #1 on:
22 March 2012, 11:31:30 pm »
You could always find an old cycle inner tube & cut it to size,probably cheaper & will have loads left over which could be used to cover the block connectors on your bike if you ride all year round to stop some of the weather getting in them?
Ray
Logged
Oxygen
Weekend Warrior
Re: Loose exhaust
Reply #2 on:
22 March 2012, 11:34:25 pm »
Will they resist the heat ?
Logged
chunk166
Naughty Corner
Weekend Warrior
Re: Loose exhaust
Reply #3 on:
22 March 2012, 11:45:12 pm »
Good Question, I'm sure it will, rubber is quite good & i doubt it will get hot enough to melt it? I'd give it a go,if you have an old tube handy it costs nothing or about £2 to buy?
Ray
Logged
Oxygen
Weekend Warrior
Re: Loose exhaust
Reply #4 on:
23 March 2012, 09:28:33 am »
I will feed back as I do have a spare/old tube
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
Loose exhaust
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
