Date: 15-03-26  Time: 01:29 am
Author Topic: Changing spark plugs FZ6 S2 Fazer  (Read 10575 times)
agricola
« on: 26 June 2017, 05:14:16 pm »
Chuff me, had a look at the manual, reads like a major task. Remove tank/airbox/radiator etc. Anyone know of any short cuts?
BBROWN1664
Re: Changing spark plugs FZ6 S2 Fazer
« Reply #1 on: 26 June 2017, 05:58:20 pm »
Get someone else to do it :pokefun
Grahamm
  • Global Moderator
« Reply #2 on: 26 June 2017, 10:53:03 pm »
Supposedly, if you have reasonably small hands, you can actually get in from the sides and, with a bit of fiddling, do it without removing lots of bits. There's a description of the technique here: http://www.sportbikes.net/forums/fz6-fz6r/361128-how-replace-your-sparkplugs-20-minutes.html
I think (although I've not tried it yet, that you could just unbolt the radiator and support it to give better access without having to take the whole thing off, but do that at your own risk!
agricola
« Reply #3 on: 27 June 2017, 09:40:20 pm »
Errr, not likely. I do all my own work, then I know its done properly (and its cheaper)
agricola
« Reply #4 on: 27 June 2017, 09:50:21 pm »
Looks like its worth a go then
acid drop
« Reply #5 on: 27 June 2017, 10:47:27 pm »
You can change the plugs by getting in from the sides but if you release the radiator mountings it will give a bit more space. Did it a few times when I had an S2
ratkinsonuk
« Reply #6 on: 03 July 2017, 01:14:38 pm »
This guy did it by just dropping the radiator, but looks like a pig of a job..
I need to do mine, so let me know how you get on.
agricola
« Reply #7 on: 08 July 2017, 05:20:27 pm »
Did it this morning, dropped the radiator but left all the pipes connected to it, just let it hang there. Bit of a faff, but doable by the average rider methinks. Plugs looked in good  order, just cleaned and gaps checked/adjusted
MMCMME
« Reply #8 on: 09 July 2017, 10:41:47 am »
I did mine last week also.
Have seen a video of a guy who managed to get them out from the sides without having to remove anything.
I removed radiator and it was still a faff on to get the leads in and out!
ratkinsonuk
« Reply #9 on: 10 July 2017, 10:03:43 am »
@agricola - how did you go about blowing the crap out of the plug holes first?
agricola
« Reply #10 on: 14 July 2017, 11:38:17 am »
Simple. I didnt. The rubber sealing caps were a real tight fit into their sockets, so i didnt feel the need to blow any crap out since there wouldnt have been any crap there.
