Date: 07-05-26  Time: 15:22 pm
Author Topic: shared carbs  (Read 1848 times)
Disorderlypunk
shared carbs
« on: 26 June 2017, 12:11:18 pm »
anyone happen to know if the 2k boxeye shared its carbs with any other model - im looking at some k+n filters for a 99 fzr600 and they are pretty close to my sketchy dimensions (good verniers battery flat so using my cheap as fuck plastic ones which are no good for precise measurements)
- seen the price of the ones rubyracing used and found some cheaper ones which might work better for harmonic resonance if they fit
daviee
  • Guest
Re: shared carbs
« Reply #1 on: 26 June 2017, 05:35:02 pm »
as long as  you  are close i dont think it has to be that accurate they will be in mm not any less that that
Disorderlypunk
Re: shared carbs
« Reply #2 on: 26 June 2017, 07:38:32 pm »
it looks like its only a few mm out between inlet centers 1&2 3&4 - prob close enough for the rubbers to allow the difference
daviee
  • Guest
Re: shared carbs
« Reply #3 on: 27 June 2017, 06:10:52 pm »
i would think so as the carbs must be spaced about the same at the inlet rubbers are the same through out that engine type as are the engines
