Date: 29-03-26  Time: 15:18 pm
Author Topic: Fazer / thundercat  (Read 4581 times)
sjdfzs
Fazer / thundercat
« on: 22 March 2012, 10:15:49 pm »
Do the wheels off a thundercat fit fazers? And the rear caliper, could it fit?mand are the any better?
Thanks
mike26
Re: Fazer / thundercat
« Reply #1 on: 22 March 2012, 10:37:26 pm »
im sure the thundercat uses a bigger wheel so unless on the furthest back setting on swingarm doubt it tbh
different swingarms
sjdfzs
« Reply #2 on: 22 March 2012, 10:45:17 pm »
I have most of a tcat so how much work would it be to get the swing arm on it?
Motorbreath
« Reply #3 on: 22 March 2012, 10:53:07 pm »
The cat fits a same width rear rim, 5".
I put a TRX 850 front rim with a 120/70 tyre and a 170/60 rear tyre, which is the actual size intended for 5" rims. It feels great.
sjdfzs
« Reply #4 on: 23 March 2012, 07:13:00 pm »
The rims are both 17" and 5" wide. I just want to make sure the axle would fit and the hub is same width.
Can the rear calipers be used as an upgrade for the fazer or are they just as bad or major job to change?
solorider
« Reply #5 on: 25 March 2012, 09:58:40 pm »
if it is any help the centre spacer and drive hub is the same as the thundercat,the splindle is different though,the disc side spacer is the same but the driven side is different,i cannot answer on the rear caliper though,the carrier is different
sjdfzs
« Reply #6 on: 26 March 2012, 06:05:09 pm »
Ok thanks. I'm trying the whole swing arm etc when I get round to it so I'll see what can and can't be done
solorider
« Reply #7 on: 27 March 2012, 12:18:33 am »
the spacer and bearings are the same but the bolt is different
