Date:
20-04-26
Time:
04:23 am
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
Seized fork bottom adjuster
« previous
next »
Print
Pages: [
Author
Topic: Seized fork bottom adjuster (Read 2684 times)
bwizz
Club Racer
on:
14 June 2017, 12:49:34 pm »
Just doing the
fork seals on my thou .The bottom compression "flat blade screwdriver adjuster" is seized.! Can I remove the threaded housing that surrounds it to gain access. Just checking before anything goes pyoing!
Logged
cl1ve2004
Weekend Warrior
Re: Seized fork bottom adguster
Reply #1 on:
14 June 2017, 07:12:27 pm »
loads of threads on this..good penetrating oil and heat (not too much!!) I had same thing on mine.. best thing is patience..
loads of info if you use "search "on here..
good luck
Logged
Mustang
Naughty Corner
Club Racer
Reply #2 on:
14 June 2017, 10:01:13 pm »
I've done a YouTube on this when I did my zx9r forks.
Logged
bwizz
Club Racer
Reply #3 on:
23 June 2017, 02:29:40 pm »
What happens if I remove the boss which holds the adgusting screw ?
Logged
cl1ve2004
Weekend Warrior
Re: Seized fork bottom adjuster
Reply #4 on:
23 June 2017, 04:05:57 pm »
others know more than me,but I think its got a really fine thread that is really easy to foc up and then its a replacement fork bottom!!
theres a picture on the threads which shows a seized one cut through section...
Logged
bwizz
Club Racer
Reply #5 on:
23 June 2017, 05:21:41 pm »
Hard to browse the site with a phone. ! But thanks!
Logged
Mustang
Naughty Corner
Club Racer
Reply #6 on:
30 June 2017, 11:05:31 pm »
Ktec do replacement adjusters
Logged
bwizz
Club Racer
Reply #7 on:
01 July 2017, 10:32:07 am »
I got sidetracked .i'm gona take the forks of again next week .and have another go .I'll report back thanks all!
Come to do the seized forks adjuster yesterday.
I removed offending fork leg and drained oil. I removed the adjuster boss no probs. Observed that the adguster screw is brass so heat is not going to do much. Tried it didn't . Tried impact screwdriver no go .well stuck! Desperation now! I cut a slot all around the screwhead approx 3 mil in . Then broke away the surrounding alloy ring. I was intending to get at the screwhead with mini mole grips! I was surprised to see that the adjuster srcew is in two parts slotted together! I removed the seized outer screw and the inner brass screw adgusts fine.
Not having or at that point realising I would need a new one. I decided to see if all was well when I refilled with oil. No leaks but no click adjustment now so just counted the turns compared to the other side. I fitted a rubber blanking gromet over the recessed screwhead and all seems to be well. I will probs fit a new adjuster when the messing mood is on me again. Not much oil came out of the boss so I don't think an issue to do in situe ! Progably a good idea to locktite the brass screw if you are faced with this problem.
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
