Date: 07-05-26  Time: 21:43 pm
Author Topic: carb heater pipe  (Read 2062 times)
stuartA8904
carb heater pipe
« on: 05 June 2017, 09:03:46 pm »
right stupid question coming up (sorry) brought a fazer in bits put most of it back together only the 2nd heat pipe for the carbs is no where iv connected the the one from the rad to the first bit on the carb left side as you sit on it but dont deem to have any pipe for the out let on the right anyone have a clue where it would be connected to (not carb end) i cant find any pics on the net of where the pipes/tubes should go i believe it may go to the thermostat housing but not sure, any help would be much appreciated thanks
Bretty
Re: carb heater pipe
« Reply #1 on: 05 June 2017, 09:58:25 pm »
deleted... (my message, I had a picture which looked ok on my phone, but rubbish on screen, so no help at all)
stuartA8904
« Reply #2 on: 06 June 2017, 08:41:47 am »
« Reply #3 on: 06 June 2017, 09:04:35 am »
It's reasonably clear in the manual: the flow is from the left hand side of the thermostat to the left carb, through the carbs and then to the spigot on the radiator. (Hoses 19 and 21 on AJ Sutton's site.)
stuartA8904
« Reply #4 on: 06 June 2017, 09:44:41 am »
Thank you, I don't have a manual as I have reading issues so generally just wing it, I thought that's where it went just wanted to get confirmation, appreciate you help
« Reply #5 on: 07 June 2017, 09:13:53 am »
Before you put everything back together, check all the elbow are clear as it's these that block causing the system to fail and icing.
