Date:
02-05-26
Time:
06:29 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
Sprung a Leak
« previous
next »
Print
Pages: [
Author
Topic: Sprung a Leak (Read 2329 times)
Tefer
Club Racer
Sprung a Leak
on:
30 May 2017, 11:32:48 am »
I have this morning had a coolant leak at the front of the engine, anyone else had this? Easy Fix?
Logged
Andy1970
CBT Wobbler
Re: Sprung a Leak
Reply #1 on:
30 May 2017, 02:42:43 pm »
This metal pipe is in two parts with a single screw holding a tubular pipe into the end of the cast section. I haven't had a leak, but when I recently stripped my engine down I tried to separate the two parts and it proved completely impossible due to the fact that they'd corroded together. I ended up scrapping the whole part and getting a decent replacement off ebay, although they're a bit difficult to find because most people who break engines sell these with the rest of the head rather than separately. Both bits are no longer available from Yamaha.
If it'll separate then you should be able to get the end metal pipe fitting off by just undoing the single bolt and pulling the pipe out. Alternatively if it's stuck fast like mine was then you'll need to remove the two parts as a whole, which is just four screws into the front of the head. Then you'll need to replace the two o rings between the fitting and the head, as well as the o ring between the two halves which is probably where the leak is.
Edit, there's one here
http://www.ebay.co.uk/itm/yamaha-600-fazer-mk1-front-water-pipe-/112292713457?hash=item1a252ad3f1:g:3qwAAOSw44BYlf1q
Andy
Logged
Tefer
Club Racer
Re: Sprung a Leak
Reply #2 on:
30 May 2017, 04:59:00 pm »
Thanks Andy, added that to my watch list, i'll access the job, see if i need that or the o-ring only.
Logged
bikemad
Weekend Warrior
Re: Sprung a Leak
Reply #3 on:
30 May 2017, 10:18:37 pm »
I had to replace the alloy manifold on one of my bikes it'd split where the steel pipe goes in,if this is the problem just be really careful removing the 4 bolts one of mine snapped off took a lot of heat & persuasion to remove it !
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
Sprung a Leak
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
