Date: 19-04-26  Time: 18:33 pm
Author Topic: Poor tickover/ popping in exhaust .  (Read 3983 times)
vivfazer
« on: 26 May 2017, 07:44:11 pm »
Hi all,
I've  balance the carbs but at tickover there is a popping in the exhaust but above 2000 revs ok.
Any ideas.
Cheers.
Falcon 269
Re: Poor tickover/ popping in exhaust .
« Reply #1 on: 28 May 2017, 08:04:51 am »
You're not giving us much to go on here.
Was the popping there before you balanced the carbs?
What gauge did you use to do the carb balancing?
How much adjustment did you make to each adjuster screw?  Typically they need less than a 1/4 turn, usually a lot less.
Do you feel any misfire/hesitation when you ride the bike?
Give us some more information and clues and we might be able to advise you more.
Gnasher
« Reply #2 on: 28 May 2017, 11:32:35 am »
One of the symptoms of bad carb balancing, why did you balance the carbs?
celticbiker
« Reply #3 on: 28 May 2017, 12:37:15 pm »
Did you replace all the blanking caps?
vivfazer
« Reply #4 on: 28 May 2017, 07:50:49 pm »
The carbs were slightly out of balance ,
The popping only happened after I had balanced the carbs.
They didn't need much adjustment.
They had not been balanced for a good few years.
I have not replaced the rubber caps.
I have the four bamk of gauges from M&P.
Many thanks for your help.
Falcon 269
« Reply #5 on: 29 May 2017, 07:33:53 am »
Check all 3 vacuum caps and the AIS hose are properly fitted and not leaking.
vivfazer
« Reply #6 on: 29 May 2017, 03:26:44 pm »
Hi,
I have sprayed wd40 over the pipe AIS pipe and rubber caps to see if the revs increased hense a leak.
The revs stayed stable so they may be working ok.
Many thank for your help.
vivfazer
« Reply #7 on: 29 May 2017, 04:35:16 pm »
Hi,
Just off tickover up to 1700 revs it does misfire / splutter.
Many thanks.
Alan.
blackcabbie
« Reply #8 on: 29 May 2017, 08:37:28 pm »
very similar to my problem.... i've done loads of research and most probable culprit is a blocked pilot jet and or perished
 float needle o rings....i'm gonna run a tank of fuel mixed with redline carb cleaner...... if that don't fix it, it's a carb off job to clean pilot jets and replace o rings
mine runs like a dog from tickover to 3k rpm  but above 3k its perfect
vivfazer
« Reply #9 on: 04 June 2017, 04:26:49 pm »
Hi,
I've checked the AIS pipe and replaced the 3 rubber caps on the carbs but its still popping in the exhaust.
I think it will have to go to a bike mechanic.
Thanks for the help.
Falcon 269
« Reply #10 on: 04 June 2017, 08:43:33 pm »
What exhaust can do you have fitted?  If it's a wide-bore aftermarket can, you might reasonably expect popping the exhaust as normal.
vivfazer
« Reply #11 on: 04 June 2017, 11:56:33 pm »
Hi,
Itsca wide bore stubby end can.
It ran fine before I balanced the carbs,
When I put the vacuum gauges on the carbs again I'm pretty sure there was no popping in the exhaust.
If I connect the vacuum gauges one by one and run the bike it may show up where the leak is if any.
It may be worth a go,
Cheers.
vivfazer
« Reply #12 on: 05 June 2017, 05:24:17 pm »
Hi,
I've just taken tbe vacuum pipe off no.4 pot for hhe AIS and replaced it with a rubber cap and the popping has stopped.
I then put the vacuum pipe back on and the popping started  again.
Do you have to remove the complete AIS system or can you disconnect the vacuum pipe and block the outlet on no.4 pop.
Cheers.
Falcon 269
« Reply #13 on: 05 June 2017, 07:36:22 pm »
Hi Viv
You can simply disable the AIS by removing the vacuum pipe from #4 intake stub as you've done.  Your popping was a combination of the AIS activating and the wide-bore can, which tends to make any popping of this kind sound more obvious.
Removing the AIS improves access to the top of the motor for plug changes etc but otherwise has no effect on performance.  A good time to do the permanent removal is when you check the valve clearances because the AIS has to be removed to get the cam cover off.
Glad you've got it sorted for now. :)
vivfazer
« Reply #14 on: 05 June 2017, 07:52:24 pm »
Hi,
Thankyou very much for your help.
I will look at removing the AIS in the nesr future.
Cheers
