Date: 01-05-26  Time: 03:54 am
Author Topic: Knocking from chain, worse when turning  (Read 3639 times)
kgjersda
« on: 15 May 2017, 09:37:21 am »
So the bike has developed a knocking-"feel" from the chain, and it gets worse whenever I turn hard left/right in slow speeds.
Could it be anything other than the need for a new chain?
Gnasher
Re: Knocking from chain, worse when turning
« Reply #1 on: 15 May 2017, 10:10:26 am »
Yep you've got a tight spot, if you can hear it while riding the chain has had it.
Fazer99
« Reply #2 on: 15 May 2017, 12:11:12 pm »
it could also be that your chain is too slacked, try giving it a good clean & adjust it properly as well as lubing before going down the route of getting new chain & Sprockets.
kgjersda
« Reply #3 on: 15 May 2017, 12:36:35 pm »
Could it be that the chain is too tight?
I know it's not too loose, but perhaps I tightened it too much...
Drezza
« Reply #4 on: 15 May 2017, 12:45:06 pm »
Check the free-play is within the specified tolerance. (can't remember what it is off the top of my head).
Fazer99
« Reply #5 on: 15 May 2017, 12:57:02 pm »
Just looking at my owners manual and it states "Normal slack is approximately 30 ~ 45 mm."
midden
« Reply #6 on: 15 May 2017, 07:53:14 pm »
If when leaning left check front sprocket hasn't come loose
kgjersda
« Reply #7 on: 15 May 2017, 08:26:46 pm »
Last time I adjusted the chain I didn't do it properly... I just picked a spot and began adjusting to roughly 30-40mm.
I now found the tightest part of the chain and measured, it was 20mm :O
Adjusted it to 35mm, sound is gone :)
But there probably is a tight spot somewhere along the chain, and one o-ring on the master link has been damaged, so it's leaking red stuff from it :/
Probably due for a new chain anyway.
« Reply #8 on: 16 May 2017, 06:55:31 am »
Buy a D.I.D. X Ring chain & sprocket kit, they're very good, tried and tested, and if looked after will last a very long time.
http://www.ebay.co.uk/itm/YAMAHA-FZS-600-FAZER-1998-2003-DID-X-RING-CHAIN-SPROCKET-KIT-X-Ring-FZS600-/400676831619?hash=item5d4a334183:m:m0zYRLEELbgh_F03D5-UADg
